CV/Axle assembly totally stuck, How do I pull them out |
JoeDees |
Oct 9 2016, 12:15 PM
Senior Member Group: Members Posts: 515 Joined: 10-November 14 From: Northern Kentucky Member No.: 18,106 Region Association: None |
These things are totally stuck in the hub. I've checked and rechecked that I have all of the bolts, and I do, but I can't get these out of the hubs/trailing arm assembly. I've soaked hem in PB blaster, but I can't figure out a way to leverage them out. Am I missing something? Any ideas?
JoeDees |
Oct 9 2016, 12:40 PM
Still stuck, but I found answers here after Google searches:
http://www.914world.com/bbs2/index.php?sho...p;#entry1562661 |
Mark Henry |
Oct 9 2016, 12:46 PM
Get the stub itself out? I use an air hammer, punches them out in seconds. You can use a big brass drift and a BFH. (IMG:style_emoticons/default/smash.gif)
mb911 |
Oct 9 2016, 12:59 PM
914 Guru Group: Members Posts: 6,879 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Ditto air hammer method is easiest.
wndsrfr |
Oct 9 2016, 01:10 PM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
These things are totally stuck in the hub. I've checked and rechecked that I have all of the bolts, and I do, but I can't get these out of the hubs/trailing arm assembly. I've soaked hem in PB blaster, but I can't figure out a way to leverage them out. Am I missing something? Any ideas? Use 'em like a slide hammer, bam, bam, bam...violence helps sometimes. |
rhodyguy |
Oct 9 2016, 02:33 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Prob rusted on the location pins. Using the axle like a dent puller can leave a pin behind. Then you're really screwed. I spent hours using threaded rod to draw the cv back on. Hours. At this point in my life, I would soak the castellated axle nut, use a 1/2" electric impact from autozone on it, get what you need to out of the way and just pull the whole thing out.
iankarr |
Oct 9 2016, 04:52 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
I made a video of removing mine, though yours sound way more stuck.
https://m.youtube.com/watch?v=7a5ACf2xK6Y hitting it with penetrating oil for a while helps if the splines are sticking. You may also need to break out the torch. |
rhodyguy |
Oct 9 2016, 06:19 PM
Well done sir! No chance of getting hurt or damaging the merchandise using that method.
einic |
Oct 9 2016, 09:50 PM
Newbie Group: Members Posts: 49 Joined: 28-May 10 From: Norway Member No.: 11,773 Region Association: Scandinavia |
I used a copper clamp around the axle, and a crow bar against this and the housing. Then I could force the axle off without hammering.
Elliot Cannon |
Oct 9 2016, 10:57 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I use anti-seize on the splines when installing. The last time I removed an axle, it slid right out.
stinkindiesel |
Oct 10 2016, 03:02 PM
Member Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
I made a video of removing mine, though yours sound way more stuck. https://m.youtube.com/watch?v=7a5ACf2xK6Y hitting it with penetrating oil for a while helps if the splines are sticking. You may also need to break out the torch. That's how I finally got mine as well. Started out with a dead blow hammer, then a framing hammer with a block of wood, then the framing hammer without the wood, then the 3 lbs sledge with a block of wood, and finally just hauled off and whacked the snot out of it directly with the sledge. I was afraid I was going to knock the car off the jack stands before the axle came loose. Gary |
JoeDees |
Oct 11 2016, 11:06 AM
I figured that everything in there will be replaced before it drives again, but didn't want the stub axle or bearings out because I need the thing rollable...
I had a buddy stand on the trailing arm assembly with the axle hanging off a curb and did the trick of hitting the axle sidewards (equivalent to down if mounted on car) with a rubber mallet, turned axel 90 degrees, <whack>, turn, <whack>, etc until it came off. It looks to me like in the decade the car sat in Texas and what not, the grease and seal melted and solidified into a super-mega glue. Like stated above, the problem now lies in the location pin stuck in there. But I'll worry about that when the stub axle gets removed when I get to my permanent garage. |
Lo-Fi Version | Time is now: 7th June 2024 - 12:40 AM |
