JPA914 |
Member ![]() ![]() Group: Members Posts: 81 Joined: 30-June 15 From: Houston, TX Member No.: 18,905 Region Association: Southwest Region ![]() |
Obviously not the bulb, as it's the same one handling both functions. This is for the driver's side BTW. The running light doesn't light up when pulling the headlight knob on the dash to either the first or second detent. Anyone have an idea what the problem might be?
malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
Some bulbs have 2 filaments. Maybe one is burned out....
If not that then you might remove the bulb and put a VOM on the contacts in the bulb socket to see if power is there (in the right place) for both functions. That is the extent of my troubleshooting.... (IMG:style_emoticons/default/mellow.gif) |
JPA914 |
Some bulbs have 2 filaments. Maybe one is burned out.... If not that then you might remove the bulb and put a VOM on the contacts in the bulb socket to see if power is there (in the right place) for both functions. That is the extent of my troubleshooting.... (IMG:style_emoticons/default/mellow.gif) Thank you for the reply. I switched the bulbs between sides and the problem stayed on the same side, so I think the bulb is OK. Good idea on using a meter to test the functions, I'll try that. |
toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California ![]() ![]() |
Does the WART light on that side work?
It's the same battery lead. . |
JPA914 |
toolguy |
probably the contactor under the bulb if the bulb is know to be good. . or the wire lead is loose off the spade under the rubber cover.
Look inside socket for corrosion, and make sure it is high enough to touch bulb base. . The brass tab can be bent upwards a tad bit. |
JPA914 |
probably the contactor under the bulb if the bulb is know to be good. . or the wire lead is loose off the spade under the rubber cover. Look inside socket for corrosion, and make sure it is high enough to touch bulb base. . The brass tab can be bent upwards a tad bit. Will do, thanks! |
jkb944t |
Member ![]() ![]() Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None ![]() |
The spade is riveted to the light assembly but the rivet may have failed allowing the spade to come loose.
Jeff B |
jkb944t |
Jeff B |
JPA914 |
Lo-Fi Version | Time is now: 19th July 2025 - 06:56 AM |
