Help with wiring a 911 dash into 1 914 |
dgraves |
Oct 11 2016, 05:29 PM
1974 914 2.0 Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains |
One of the previous owners of my newly acquired 1974 2.0 914 replaced the 3-gauge cluster dash with a 5-gauge 911 cluster. Unfortunately when it was wired, they used all red wire. It's really a mess and I'd like to "clean it up". Has anyone done this conversion and if so, here's what I really need help with. I have one gauge combo for Oil Temp and Oil Pressure (It is a 911 add on gauge combo). Neither are working and when I pulled it out, there was nothing but red wires scabbed everywhere.
Any wiring directions for this combo gauge into a 914? Thank you, Dan (IMG:style_emoticons/default/WTF.gif) |
GeorgeRud |
Oct 11 2016, 08:35 PM
Ouch! Getting rid of that red wire is first, then I'd use the same color of wire that a 914 or 911 use for these gauges. If your 914 had the center console gauges, you should have some wiring to tap into. Use the 914 current flow diagram to help decide the colors, though unless you've added a different pressure sender, you won't have the necessary wire for the pressure gauge and will have to run another wire for that gauge through the center tunnel. Keep notes for subsequent owners of the wiring.
Lo-Fi Version | Time is now: 6th June 2024 - 10:11 PM |
