Gas Mileage, What are you getting, city/highway? |
pbanders |
Oct 17 2016, 08:47 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
Yes, it's been done before, but how about an update? I'll go first:
1970 914 w/'74-spec 2.0L D-Jetronic, stock w/Euro pistons, Crane XR-3000 ignition and Crane coil. City: 24 mpg / Highway: 39 mpg (flat road, 75 mph, 80 mile trip) What are you getting? The 914's a lot better than my '03 Boxster. |
Coondog |
Oct 17 2016, 09:31 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Drove from Phoenix to Apple Valley, Ca. Used 3/4 tank, never really been that gas mileage guy unless I am driving my motorhome then I try to squeeze 9-10 miles per gallon.
pbanders |
Oct 17 2016, 09:36 PM
Drove from Phoenix to Apple Valley, Ca. Used 3/4 tank, never really been that gas mileage guy unless I am driving my motorhome then I try to squeeze 9-10 miles per gallon. According to Google, 353.2 miles. 16.4 gal tank with 2 gal reserve -> 14.4 * 0.75 = 10.8 gal, which works out to 32.7 mpg, pretty good! |
cali914 |
Oct 17 2016, 09:54 PM
cali914 Group: Members Posts: 447 Joined: 26-April 06 From: Berkeley Ca. Member No.: 5,934 Region Association: Northern California |
18 city 25 highway v6 honda engine
SirAndy |
Oct 17 2016, 10:57 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Gas Mileage, What are you getting, city/highway? 1970 914 with a '95 993 3.6L engine Highway: ~25 mpg City: ~20 mph Track: ~5 mpg (IMG:style_emoticons/default/driving.gif) |
914_teener |
Oct 18 2016, 12:13 AM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Spec 1.7 205-60 tires D- jet
City 28 Highway 39 I've been trying to kill this engine for years and it just keeps going and going. |
Porschef |
Oct 18 2016, 04:07 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Good question. I'd like to figure out what's keeping mine down, other than my right foot. Top off, maybe 24 at best on the hwy, less locally.
2056, 9550 cam, Ljet, 9:1 comp, 13:1 AFR... (IMG:style_emoticons/default/confused24.gif) |
BeatNavy |
Oct 18 2016, 04:18 AM
Good question. I'd like to figure out what's keeping mine down, other than my right foot. Top off, maybe 24 at best on the hwy, less locally. 2056, 9550 cam, Ljet, 9:1 comp, 13:1 AFR... (IMG:style_emoticons/default/confused24.gif) I'm kind of in the same boat. To and from work (90% of my driving) I'm lucky to get 20 mpg. That's "parkway" driving where it's 60 mph for a mile or two and then stop for the light. Rinse and repeat. I probably got more like 25 mpg up and back to Hershey, the longest continuous trip I've taken it on. 2056 with stock cam and I might be slightly rich at warm up (using the CHT spacer) but AFR readings are slightly lean, if anything, after that. The only working theories I have now on what may be keeping my mileage down, other than possibly the CHT spacer and the nature of my driving, is my battery has been flaky the last couple of months due to a parasitic drain on it. I'm certain a weak battery doesn't help mileage or performance, but otherwise I'm not sure if I should be doing significantly better or if "it is what it is." I read about you all getting 30+ mpg.... (IMG:style_emoticons/default/confused24.gif) |
Bleyseng |
Oct 18 2016, 08:09 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
22 city and 27-30 highway
2056 w/9550 cam 9to1CR |
DRPHIL914 |
Oct 18 2016, 08:28 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Stock 75 2.0 d-jet with back dated SS HE and triad exhaust,
usually 25-6 around town straight city, 29-30 combined, and last trip was octeenerfest and we averaged about 33-35 MPG for the trip(some mountain road driving. and I was running a bit rich so I feel like I could get a bit better for straight freeway driving closer to the speed limit, no mountains, im going to to another test here soon before pulling it off the road to paint, I'm going to drive to work for a while, which is a 25 mile commute, mostly 65mph highway with a few miles of city driving, - I will post my results on the next tank. Dr. Phil |
Porschef |
Oct 18 2016, 09:56 AM
Rob, I also feel that my dizzy/voltage could be a factor; I've never dismantled the distributor and its history is unknown to me. The Ljet system was complete and in pretty good shape when I got it, injectors aside. They needed rebuilding. So maybe the round thing under the cap and rotor needs going through.
Geoff, mines the same. Although every time I read your signature I see L jet... (IMG:style_emoticons/default/blink.gif) |
JustinMeier |
Oct 18 2016, 01:06 PM
Member Group: Members Posts: 244 Joined: 3-August 16 From: Scottsdale Member No.: 20,258 Region Association: None |
2.7 going to RRC I was getting about 24 highway.. 75-80, around 3-4k rpm.
sb914 |
Oct 18 2016, 01:33 PM
Surf Guru Group: Members Posts: 4,316 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
About 8 miles per gallon, and I don't give a Fuch! (IMG:style_emoticons/default/beer3.gif)
Chris914n6 |
Oct 18 2016, 08:44 PM
Jackstands are my life. Group: Members Posts: 3,338 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
24/29 with the 3.0 Nissan
bandjoey |
Oct 18 2016, 09:01 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
2.0 stock other than carbs
190 mile highway trip 30.3 mpg |
mankowski |
Oct 18 2016, 10:51 PM
Member Group: Members Posts: 128 Joined: 7-February 10 From: Portland, Oregon Member No.: 11,335 Region Association: Pacific Northwest |
Stock 1.7, Djet. Average: 23 MPG. Range: 15-30 MPG, with lots of variation. I've spent a lot of time trying to figure this out. I even correlated the number of days between refills and MPG for the tank across several thousand miles. My thinking was that gas was evaporating through the broken vacuum lines running from the fan to the charcoal canister, or some other unknown leak. Correlation was -.35 (more days between tanks = lower gas mileage). It's time to get those lines repaired and check again.
Any other ideas? |
Lo-Fi Version | Time is now: 10th June 2024 - 03:17 AM |
