Jamie |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,037 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States ![]() ![]() |
I can't believe that there isn't an extra wrench out there somewhere- I didn't get a single response to my post yesterday?
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
I got one.
Jamie |
Can you give me a price including shipping to KY- I also need the wire claw for removing hubcaps with 2 holes if you have it. Thanks for the reply.
nyum96 |
Member ![]() ![]() Group: Members Posts: 75 Joined: 27-September 03 From: Roswell, GA Member No.: 1,200 ![]() |
If all else fails, a VW new beetle wrench will work. Not original but.... thats what I use. Its also small.
BB |
URY914 |
Is there a differance between a 914 and a VW lug wrench? |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Ha, same part number same everything but when put in a Porsche it doubles the value (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
Are we talking about the cheap pressed steel tube with a formed hex shape at one end and a hole through the other end for a little lever bar to pass through? I put a 1/2" Craftsman flex handle with a deep socket in my trunk as soon as I saw that thing in the tool pouch! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
nyum96 |
Here is a picture. For those interested, P/N 4D0012219A. Audi/VW part. I know when I added it to my tool kit, my car went up a couple of bucks in value. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
I would say it (the part) is no longer than 12 inches. BB Attached image(s) ![]() |
Jamie |
So what does the original 73 wrench look like? If it's a stamped/pressed cheapo I might not have recognized it when I picked thru Dad's collection of "stuff" he had stored in the trunk. That's why I didn't recognize the wire claw for removing hub caps- there were no hub caps!
URY914 |
I don't have one of those. I got the cast iron ones like the VW's. Paul (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) |
Cap'n Krusty |
The original lug wrench is a stamped steel tube with a couple of holes near the outer end for the foot long (if that) steel rod to pass through it. The Cap'n
URY914 |
Here is a stock 73 tool kit.
Attached thumbnail(s) ![]() |
URY914 |
Same as a VW Bug.
maf914 |
I think that tool kit is the same as the one that was in my 76. Same lug wrench at least. I don't know if the screwdriver in my kit comes apart like that one though, since I don't think I ever used it. What is the little u-shaped wire tool for? To pull something? Or to screw in a bezel? |
URY914 |
You pull the hub caps off with it.
The h/c have two holes in them on the edge and you stick the ends of the U in the holes and pry it off with the bar. Paul |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,535 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
That hubcap clip has been a mystery to me...the 74-76 cars never came from the factory with hubcaps...
(IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
michaelmoo |
Member ![]() ![]() Group: Members Posts: 312 Joined: 21-May 04 From: Kennesaw, GA Member No.: 2,092 ![]() |
The screwdriver also can have a black handle. Mine is original and has a black plastic handle.
Lo-Fi Version | Time is now: 11th June 2024 - 09:17 AM |
