Dashboard HVAC control |
Racer |
Oct 19 2016, 04:34 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
Last weekend I stirred my 914 out of its slumber while it was still dark. To my wonderful surprise, lights worked- taillights, headlights, license plate lights, trunk light too... I was reminded that the radio and HVAC also light up!
Sadly, when I went to turn on the fan, to get air blowing into the cabin, I got nothing. No noise, no sparks, just quiet. So.. what are some suggestions to check - Contacts in the control unit? Fuse panel? What are the usual fail points? Do the motors seize up (not sure when it was last used) TIA. |
theleschyouknow |
Oct 19 2016, 05:09 PM
Senior Member Group: Members Posts: 523 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None |
do the horn and lighter work?
I think they all share a relay, maybe wipers too? (IMG:style_emoticons/default/beerchug.gif) cjl |
Racer |
Oct 19 2016, 05:55 PM
do the horn and lighter work? I think they all share a relay, maybe wipers too? (IMG:style_emoticons/default/beerchug.gif) cjl I will have to double check, but I am pretty sure those items work. |
steuspeed |
Oct 19 2016, 07:40 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Might just need a fuse wiggle. That can happen when it sits a while.
zambezi |
Oct 20 2016, 10:19 AM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
most likely corrosion on the sliding contacts of the dash levers.
Lo-Fi Version | Time is now: 10th June 2024 - 03:13 AM |
