Rekeying Ignition Tumbler, What works to remove the two rolled pins ? |
jim_hoyland |
Oct 21 2016, 04:31 PM
Get that VIN ? Group: Members Posts: 9,318 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The pins are almost impossible to get a grip on. markB says they can be pushed through per the Rekeying Thread but I don't feel them moving yet.
Right now I'm soaking the pin portion in PB Blaster. Anyone figure out a better way to remove them ?? http://www.914world.com/bbs2/index.php?sho...c=66709&hl= Attached image(s) |
markb |
Oct 21 2016, 08:50 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
They only push thru if the key is out. Try a small pair of nippers or wire cutters to pull on them.
jim_hoyland |
Oct 21 2016, 09:08 PM
I have the key out; I don't have a small enough tool to grab the pin. There's minimal clearance around the pin and my smallest needle nose pliers won't let me grip the pins edge....... (IMG:style_emoticons/default/sad.gif)
TheCabinetmaker |
Oct 22 2016, 02:11 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I use a small drift pin punch and drive them both out from one side.
ConeDodger |
Oct 22 2016, 03:00 PM
Apex killer! Group: Members Posts: 23,611 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I use a small drift pin punch and drive them both out from one side. (IMG:style_emoticons/default/agree.gif) |
jim_hoyland |
Oct 22 2016, 03:51 PM
Is the drift punch round ? If so, I have a set....
Rand |
Oct 22 2016, 04:04 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Is the drift punch round ? If so, I have a set.... Depends on the hole. (IMG:style_emoticons/default/tongue.gif) This one yes. Big enough to get solid impact on the pin, small enough to clear the chamber it's pressed in. |
jim_hoyland |
Oct 22 2016, 04:36 PM
Is the drift punch round ? If so, I have a set.... Depends on the hole. (IMG:style_emoticons/default/tongue.gif) This one yes. Big enough to get solid impact on the pin, small enough to clear the chamber it's pressed in. Got it: will give it a try..... |
jim_hoyland |
Oct 22 2016, 05:43 PM
The drift did the trick- thanks (IMG:style_emoticons/default/smile.gif)
I assume the original roll pins can be reused ? Attached image(s) |
TheCabinetmaker |
Oct 22 2016, 07:54 PM
Absolutely
Lo-Fi Version | Time is now: 7th June 2024 - 10:36 AM |
