Broke oil Pump drive, Can the broken pcs be removed easily |
North Coast Jim |
Oct 23 2016, 06:44 PM
Member Group: Members Posts: 326 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
A new engine build required the engine to be removed from the car to replace a broken oil pump gasket on the new Mellling oil pump. As the engine was out I thought I'd do a double check of the valve clearances as this was one of the root causes issue of carb backfire/popping. Got a shop towel caught within the oil pump gears as I was hand turning the engine over by the blower fan. Broke the oil pump drive tang. Two pcs of the drive tang are now in the cam reservoir of the crankcase. Any chance of getting these things out without splitting the case again ???
Just sick over this development (IMG:style_emoticons/default/confused24.gif) |
ConeDodger |
Oct 23 2016, 06:59 PM
Apex killer! Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Magnet?
North Coast Jim |
Oct 23 2016, 07:01 PM
Mark Henry |
Oct 23 2016, 07:28 PM
Try standing it on it's nose, do it on blocks so you can try the magnet again.
Look on the bright side, at least you can toss that total POS melling and put in a 26mm pump. (IMG:style_emoticons/default/shades.gif) |
North Coast Jim |
Oct 25 2016, 05:07 PM
A new engine build required the engine to be removed from the car to replace a broken oil pump gasket on the new Mellling oil pump. As the engine was out I thought I'd do a double check of the valve clearances as this was one of the root causes issue of carb backfire/popping. Got a shop towel caught within the oil pump gears as I was hand turning the engine over by the blower fan. Broke the oil pump drive tang. Two pcs of the drive tang are now in the cam reservoir of the crankcase. Any chance of getting these things out without splitting the case again ??? Just sick over this development (IMG:style_emoticons/default/confused24.gif) Tried a vacuum fixture I made which separated oil before my vacuum source. Was able to get my pick up under the cam and around the area within the crankcase. No broken pcs found. Gave up and am prepping the motor to split the case. Goes back to the builder tomorrow. Stupid stupid me now lighter in the wallet, |
porschetub |
Oct 25 2016, 08:42 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
A new engine build required the engine to be removed from the car to replace a broken oil pump gasket on the new Mellling oil pump. As the engine was out I thought I'd do a double check of the valve clearances as this was one of the root causes issue of carb backfire/popping. Got a shop towel caught within the oil pump gears as I was hand turning the engine over by the blower fan. Broke the oil pump drive tang. Two pcs of the drive tang are now in the cam reservoir of the crankcase. Any chance of getting these things out without splitting the case again ??? Just sick over this development (IMG:style_emoticons/default/confused24.gif) Tried a vacuum fixture I made which separated oil before my vacuum source. Was able to get my pick up under the cam and around the area within the crankcase. No broken pcs found. Gave up and am prepping the motor to split the case. Goes back to the builder tomorrow. Stupid stupid me now lighter in the wallet, I would leave them they are to big to cause any harm,they will fall to the bottom of the crankcase,they are magnetic u could fish them out . However I'am at a loss to see how this would happen,a shop towel causing the oil pump drive gear to shear?????? Please explain ,thanks. |
porschetub |
Oct 25 2016, 09:28 PM
Mark Henry |
Oct 25 2016, 09:44 PM
Try breaking a small chunk off of a rare earth magnet and tape it the the end of a coat hanger wire.
You can bend the wire into different shapes to try and get into every nook and cranny. Make damn sure the magnet is secure on the wire, I'd use gorilla tape. The tang/drive on a melling is cast? Another reason not to like them. (IMG:style_emoticons/default/stromberg.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 10:23 AM |
