> Ignition Switch Pins, Seems fine without the two tiny ones
DaveO90s4
post Nov 4 2016, 04:44 AM
Hi all,
My ignition switch was playing up so I replaced it.
The old (original) one has the four big pins plus the two small pins (like the photo attached)
The one I got has all the same four big pins, but does not have the two small pins
But everything seems to work properly with the new switch (minus the two small pins), horn, indicators, lights, radio, brake lights, the lot all seem to work ok. Car starts too - which is a bonus (IMG:style_emoticons/default/evilgrin.gif)
Can anyone please tell me what the two small pins are for and what I can expect to not work with a switch that does not have them?
Thanks all in advance,
DaveAttached Image
Replies(1 - 3)
jim_hoyland
post Nov 4 2016, 09:17 AM
Get that VIN ?
IIRC one small pin connects to the buzzer circuit; when the key is left in the ignitions, its carrying 12v
The second one allows powers the Right or Left parking lights. When key if off and the turn signal switch is in the R or L position, the lights come on
You can verify this with a multimeter on the bench; test continuity between the small pins and 30
DaveO90s4
post Nov 5 2016, 06:30 AM
Thanks Jim, that's very helpful. I'm happy to not ave any buzzer system and happy to not have the sidelights on with indicator on with ignition off battery draining feature. But I now find my blue high beam light does not illuminate. Maybe that is due to one of the two small pins missing. Or possibly some completely new and baffling problem. CheersDave
jim_hoyland
post Nov 5 2016, 09:56 AM
Get that VIN ?
High bean light is not related, could be the bulb or a loose bulb connection. Test with the MM
- Lo-Fi Version Time is now: 16th June 2024 - 08:19 PM
