> Foglight LED bulb?, Ba20s socked LED
falcor75
post Nov 9 2016, 03:01 AM
Has anyone found as suitable Ba20s socket LED bulb to use in the foglights?
Replies(1 - 16)
DRPHIL914
post Nov 9 2016, 01:23 PM
Dr. Phil
I asked the same question on the thread for the 914rubber LED headlights but didn't get a response.
for the 75-76 ones I would think someone has done this?
eric9144
post Nov 9 2016, 01:39 PM
Been hunting for these for a while--to the point where I'd even considered a bulk buy out of China, but dealing with China wasn't working out so well so I gave up --last piece of my LED puzzle (IMG:style_emoticons/default/popcorn[1].gif)
Mikey914
post Nov 9 2016, 05:19 PM
The rubber man
Let me see what I can find. I have a set of these I need to install so why not.
bdstone914
post Nov 9 2016, 05:37 PM
bdstone914
QUOTE(Mikey914 @ Nov 9 2016, 05:19 PM) *
I got one from a local FLAPS. I can pull them and see what we used. The light pattern was an issue as the small reflector bounces the light back to the big reflector and the LED was more concentrated then the original bulb.
913B
Post #8018 for $14 for the pair, I bought a set too, yeah but it doesn't look OE ? but what the hell it's only $14 for LED and no wiring upgrade needed. (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/confused24.gif)
http://www.914world.com/bbs2/index.php?sho...774&st=8000
Mikey914
post Nov 9 2016, 05:59 PM
The rubber man
Well I'm bringng in the Late ones
falcor75
post Nov 9 2016, 11:57 PM
QUOTE(porsche913b_sp @ Nov 10 2016, 12:37 AM) *
I'd prefer something that can be used with the original glass. Yeah I'm picky. (IMG:style_emoticons/default/biggrin.gif)
eric9144
post Nov 10 2016, 03:47 PM
QUOTE(falcor75 @ Nov 9 2016, 09:57 PM) *
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/beerchug.gif)
Spoke
post Nov 13 2016, 09:14 PM
Jerry
QUOTE(falcor75 @ Nov 10 2016, 01:57 AM) *
Does the glass on the stock foglight come off from the reflector? I was thinking of making an LED board to fit inside the cavity and use the original glass.
Cairo94507
post Nov 13 2016, 09:22 PM
Michael
Jerry I am in. Yes the fog light lens comes off the factory lights. This is one of the last exterior lights I need for my car. Wait....did you already make the warts? If not, I still need them. If you made them, I likely have them. This is what happens when a build spreads out over years. I have forgotten some of the parts I have already bought. (IMG:style_emoticons/default/beerchug.gif)
ConeDodger
post Nov 13 2016, 10:09 PM
Apex killer!
QUOTE(Spoke @ Nov 14 2016, 12:14 AM) *
You da man! Count me in too!
Mikey914
post Nov 14 2016, 01:00 AM
The rubber man
I think the reflective dish makes the part. A flat board would not be that effective as it would not be focused.
I'm also working on new seals for these.
I'll post picks with the LED bulbs installed.
morgan_harwell
post Nov 14 2016, 09:20 AM
Ha! Finally snuck up on a camera!
SOT
My non-stock 914 driving lights use H2 bulbs.
Has anyone here found a LED replacement for H2 bulbs?
Spoke
post Nov 14 2016, 11:55 AM
Jerry
QUOTE(Mikey914 @ Nov 14 2016, 03:00 AM) *
Is this the 75-76 fog light? The early round one is the one I was thinking of. If I did these I would investigate using surface mount LEDs like Cree's XBD series.
The XBD series are so bright the datasheet has a warning about eye injury:
Vision Advisory Claim
WARNING: Do not look at exposed lamp in operation. Eye injury can result. See the LED Eye Safety application note at
www.cree.com/xlamp_app_notes/led_eye_safety.
Using the XBD with a focusing lens like Carlco's Luxeon 10mm 10412 would give a Full Width Half Maximum (FWHM; 1/2 power angle) of about 18 degrees. This is 9 degrees off of center in all directions. There are tighter lenses available as weel
For comparison, a lamp that was installed by pbanders claims 30 degree FWHM.
LEDs From Amazon
I used the XBDs on the first working 914 LED brake board which are in my car now. Here's a couple of pics from the first time I powered them. They were dangerously bright and I ended up cutting down the current from 300ma to 45ma for each LED.
eric9144
post Apr 3 2017, 10:18 AM
Found a shop in Australia that makes an LED BA20s for the early style (round) fog lights, ordering today, will let you guys know how it goes.
Mikey914
post Apr 3 2017, 10:25 AM
The rubber man
Let us know I tried a few and the bulb didn't fit.
- Lo-Fi Version Time is now: 4th March 2026 - 07:04 PM
