Quick Show and Tell, Wiper switch difference between 72-74 & 75-76 |
914Sixer |
Nov 9 2016, 07:59 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I wanted to show the difference between the mid year switch 72-74 and why the 75-76 is different. Early switch has a mounting plate 10mm thick, 75-76 is only 5 mm thick. 75-76 shows to use a different turn signal switch BUT you can use the 72-74 switch.
Attached image(s) |
76-914 |
Nov 9 2016, 08:58 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
That reminds me; I still haven't installed either one of those switches that I bought from you. Seems like there is always something else going on. (IMG:style_emoticons/default/confused24.gif)
jim_hoyland |
Nov 10 2016, 09:11 PM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Is the 924 switch like the 75 - 76 ? I have a 924 switch, curious (IMG:style_emoticons/default/smile.gif)
914Sixer |
Nov 11 2016, 07:37 AM
Yes it should be the same.
Kansas 914 |
Nov 11 2016, 08:08 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
Thanks Mark - good info. I thought they were compatible across all years.
Luckily I have a early 72, a 74 and a 75 so my stash of switches will work somewhere. |
Lo-Fi Version | Time is now: 1st June 2024 - 11:17 PM |
