914Sixer
Nov 9 2016, 07:59 PM
I wanted to show the difference between the mid year switch 72-74 and why the 75-76 is different. Early switch has a mounting plate 10mm thick, 75-76 is only 5 mm thick. 75-76 shows to use a different turn signal switch BUT you can use the 72-74 switch.
76-914
Nov 9 2016, 08:58 PM
That reminds me; I still haven't installed either one of those switches that I bought from you. Seems like there is always something else going on.
jim_hoyland
Nov 10 2016, 09:11 PM
Is the 924 switch like the 75 - 76 ? I have a 924 switch, curious
914Sixer
Nov 11 2016, 07:37 AM
Yes it should be the same.
Kansas 914
Nov 11 2016, 08:08 AM
Thanks Mark - good info. I thought they were compatible across all years.
Luckily I have a early 72, a 74 and a 75 so my stash of switches will work somewhere.
