Fog Light Wiring Help, Fog Light Wiring Help |
simonjb |
Nov 14 2016, 09:52 AM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
When I purchased my car, my cars Fog lights didn't work and the Headlights came up and on on the first (as compared with the second) pull of the Headlight switch. Looks like there was some shorting and the PO had some rewiring done.
So after reading everything and spending hours on the wiring charts (and under my dash) I got everything to work properly again. But with one exception. When I turn on the fog lights they only come on when I pull on High beam, instead of low beam. I tried to figure this out and I tried the rewiring idea to make them on all the time, but to no avail. I am sure I must have a wire crossed but can't seem to figure it out. Help! |
PancakePorsche |
Nov 14 2016, 10:28 PM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
Fog light pick off wire on headlight switch should be #56 (low beam) #56A is high beam circuit.
You may want to consider moving this wire to #15 so fogs work with headlights off (like daytime running lights) thats how I wire mine. |
IronHillRestorations |
Nov 15 2016, 07:20 AM
I. I. R. C. Group: Members Posts: 6,732 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I just went through this on a customer's car. When you turn on the fog lights with low beams, they fogs should be on. They switch off when you turn on the high beams, using the high beam indicator circuit to switch the relay so the lights are off. Sounds like you may have the relay wired backwards. It is a double throw relay.
Lo-Fi Version | Time is now: 16th June 2024 - 11:50 PM |
