forrestkhaag |
Senior Member ![]() ![]() ![]() Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region ![]() |
Does anyone out there have a good recommendation and experience with costs and availability for a well informed combo gauge for my conversion? I am building a 3.0 fairly stock save a cam grind to address tripple Webers.
I will have fuel, oil level and pressure, but maybe would want fuel pressure head temps etc. / or maybe that is a separate set of gauges replacing my current ones or the clock. Who cares what time it is in a 914-6 with Webers screaming in your ears anyway....? (IMG:style_emoticons/default/beer3.gif) Attached thumbnail(s) ![]() |
904svo |
904SVO ![]() ![]() ![]() Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 ![]() |
Look for a triple gauge or Quad gauge from McMark (I think that's his name)
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,842 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,732 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
I like using the 911 combo gauge (oil temp & oil press) in place of the 4 fuel gauge, and then getting a fuel gauge, or having the tach modded with a fuel gauge in the bottom. Since you have gauges in the dash, I'd just go with oil temp and oil pressure in lieu of the clock and volt gauge.
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,341 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
Early 944 quad gauge and replace the warning lights with press & level.
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
I have a gauge from a 2.7 911 easy to read ,got my sender units off ebay a seller called industrial-stuffs good servive and prices for VDO gear ,PO had fitted a 52mm fuel gauge in the dash about where the cig lighter would be,good spot and easy to read,thinking I might put an amps gauge on the other side (IMG:style_emoticons/default/idea.gif) .
Triple gauges are nice however ,depends on your budget really. |
napasteve |
914 driving winemaker ![]() ![]() ![]() Group: Members Posts: 504 Joined: 2-January 13 From: Napa, CA Member No.: 15,327 Region Association: Northern California ![]() ![]() |
New Vintage Gauges made this one:
jfort |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,137 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest ![]() ![]() |
my gauges, for what it's worth. I have a shift light right above the tach, too.
type47fan |
It Looks Better In Person. . . ![]() ![]() ![]() Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California ![]() ![]() |
Mine, with 911 oil temp/pressure in dash and a GT style fuel gauge in the console. ![]() ![]() |
gulf908 |
Member ![]() ![]() Group: Members Posts: 124 Joined: 25-December 13 From: Sydney Member No.: 16,795 Region Association: Australia and New Zealand ![]() |
I have the 911 oil temp/pressure in the lhs of the dash and here is the gas and volts in the console.
FHK - Oil level gauge ??? how did you do the tank sender ? Cheers Dennis (IMG:style_emoticons/default/smile.gif) Attached image(s) ![]() |
forrestkhaag |
From what i recall. my past 911's all had an oil level gauge that sloshed back and forth until the oil was up to operation temp.
In any case Vintage Gauge no longer does any Porsche work so it is off to North Hollywood Gauge............ $$$$$$$$$$$$$$$$$$$:miles: (IMG:style_emoticons/default/beerchug.gif) |
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,820 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
If you're planning on dealing with North Hollywood don't be in a rush. They are so backed up I couldn't even get an estimate on how long my order was going to take. Finely gave up and cancelled it
Cairo94507 |
It seems that most of our go-to experts are just swamped. Palo Alto Speedo did my gauges and it was about a 1 year project. Harvey Weidman has had my 5 deep sixes for 2 years now and though they were almost done 1 year ago, I still have not received them. And, we all know Scotty needs about 4 clones of himself to keep up with the work he has going on. (IMG:style_emoticons/default/beerchug.gif)
It is just part of being the best at what you do and us mere mortals have to wait for the fruits of their labor. (IMG:style_emoticons/default/driving.gif) |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I have the 911 oil temp/pressure in the lhs of the dash and here is the gas and volts in the console. FHK - Oil level gauge ??? how did you do the tank sender ? Cheers Dennis (IMG:style_emoticons/default/smile.gif) Don't bother with an oil level gauge. Even in a 911 they are'nt usually accurate. Use the dipstick on a running, warm car. |
Lo-Fi Version | Time is now: 17th June 2024 - 04:30 AM |
