| McMark |
Nov 14 2016, 11:19 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Nearly finished with the second incarnation of my air conditioning air box. Stock location, stock vents, stock fan, and no body mods.
This is the continuation of the A/C compressor project thread. Attached thumbnail(s) |
| timothy_nd28 |
Nov 14 2016, 11:26 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest
Thank you! (IMG:style_emoticons/default/pray.gif)
| rfinegan |
Nov 14 2016, 11:32 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,194 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
Woot...look'n GOOD
| JmuRiz |
Nov 14 2016, 12:09 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,623 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
WOW, this and 914/6 heaterboxes. You guys are spending my money!
| dlee6204 |
Nov 14 2016, 12:30 PM
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
Awesome! (IMG:style_emoticons/default/thumb3d.gif)
Is there any concern with the stock fan not pushing enough air for this to really be effective? |
| McMark |
Nov 14 2016, 01:35 PM
Awesome! (IMG:style_emoticons/default/thumb3d.gif) Is there any concern with the stock fan not pushing enough air for this to really be effective? No idea. How would I know? (IMG:style_emoticons/default/wink.gif) We'll see soon enough, and don't forget while the car is in motion there is a high pressure zone pushing air into the air box. This is how designing custom parts works. You gotta put down the pencil at some point and just build it, then see how it works. |
| Steve |
Nov 14 2016, 02:38 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,028 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Is there an option to recirculate the air through it? Otherwise your always competing with the outside air.
Awesome job though!! Are you going to sell any of this ala carte? |
| timothy_nd28 |
Nov 14 2016, 04:17 PM
Also, could you make it big enough to stuff a heater core in?
| 76-914 |
Nov 14 2016, 07:28 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Also, could you make it big enough to stuff a heater core in? I'll bet his design is for an Air Sucker so he'll probably keep the stock heat. (IMG:style_emoticons/default/beerchug.gif) |
| McMark |
Nov 15 2016, 07:45 AM
| Luke M |
Nov 15 2016, 01:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,497 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
Hey Mark,
I know you're working on a a/c compressor mount for the 6 version but did you happen to see the December Excellence? Check out page 81 there's a neat a/c install off the rear of the alt. Figured I pass this along in case it was missed and another way to get the compressor installed in a 914 w/o cutting into the firewall. Keep up the great work. |
| Steve |
Nov 15 2016, 08:16 PM
Hey Mark, I know you're working on a a/c compressor mount for the 6 version but did you happen to see the December Excellence? Check out page 81 there's a neat a/c install off the rear of the alt. Figured I pass this along in case it was missed and another way to get the compressor installed in a 914 w/o cutting into the firewall. Keep up the great work. Too bad there was no pictures or more information. |
| db9146 |
Nov 15 2016, 10:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None
If you look carefully at the photo of the engine in the car on page 81, you can see the AC compressor over near the 1-3 bank of ITBs (blue and red line caps, belt tensioner, pulleys, etc.). He must have had the shaft of the alternator extended through the engine shroud and then mounted the compressor at the back of the engine over the 1,2,3 bank. Never seen that before!
Then you could run the lines to the condensor over in the right rear fenderwell (with a fan for cooling) or even under the engine lid like we've seen on the board here. |
| Steve |
Nov 16 2016, 12:02 AM
There's a better picture of the engine compartment on Excelence magazines web site.
https://www.excellence-mag.com/issues/242/a...=4#.WCvyNLU76Ec |
| sixnotfour |
Nov 16 2016, 12:33 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,184 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
that's a really ingenious setup, I like the electric approach..
plenum looks good McMark.. https://www.seanhylandmotorsport.com/SHM-el...compressor-3753 |
| JmuRiz |
Nov 16 2016, 07:55 AM
There's a guy on the bird board from the UK that's working on a electric compressor system too. That may work (if you get a better alternator)
| Steve |
Nov 16 2016, 04:36 PM
The guy from the U.K. Is developing an electric system based on the benling Dm18a7 compressor.
| rgalla9146 |
Nov 16 2016, 07:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
What a great idea.
It's the only place on a 911 block where there are mounting points that can handle such a load. I'd like to see that alternator shaft. Or extension. Or however they did it. It has a serpentine drive for the alternator/AC. Good thing. Between the electric compressor idea and this there should be good AC for the 6 cylinder cars soon. Fingers crossed ! |
| JmuRiz |
Nov 16 2016, 08:50 PM
MFI pump drive (IMG:style_emoticons/default/confused24.gif)
| rgalla9146 |
Nov 17 2016, 07:44 AM
MFI is not gonna happen with this set up. No room for both pump and compressor in that area. The compressor is not driven by the MFI cog belt from the 1-3 cam. The accel. linkage must be interesting ! |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:50 AM |
