| Mikey914 |
Nov 15 2016, 06:53 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
This is an "improved" kit that uses a slightly softer high temp silicone to seal the cover plate that joins the blower housing to the sheet metal portion of the heat exchanger on the bottom.
I have included 4 allen head screws with washers. These allow you to get good tension on the screw, and to remove easily without destroying the screw. I can provide as cork if you prefer at the same cost, but This should be a reusable gasket that is now inexpensive! Compare to 021256325A and 021256326A These go where the sheet metal attaches to the blower. The ones I removed were pitiful. Most are missing completely. http://shop.914rubber.com/021256325A-02125...m?categoryId=-1 Attached thumbnail(s) |
| rhodyguy |
Nov 15 2016, 07:00 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Nice mark. They used to be cost prohibitive elsewhere.
| BeatNavy |
Nov 15 2016, 07:33 PM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,962 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
Nice Mark. I'm definitely in for a set. I need my heat this time of year (IMG:style_emoticons/default/beerchug.gif)
| Rob-O |
Nov 15 2016, 07:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,312 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region
I'll take a set right now. Working on the heat for my car right now. Had no idea these even existed!
| Mikey914 |
Nov 16 2016, 12:05 AM
PMs sent
| mzalanka |
Nov 16 2016, 12:59 AM
Member ![]() ![]() Group: Members Posts: 116 Joined: 11-July 11 From: Portland, OR Member No.: 13,300 Region Association: None |
Want.
Just got a new set of brackets from bstone. |
| Niklas |
Nov 16 2016, 01:51 AM
Porsche 914 Sweden ![]() ![]() Group: Members Posts: 368 Joined: 20-June 09 From: Sweden - Skivarp Member No.: 10,488 Region Association: Scandinavia |
3 sets for me.
| jrblackbox |
Nov 16 2016, 02:05 PM
Member ![]() ![]() Group: Members Posts: 285 Joined: 8-September 15 From: Easton, CT Member No.: 19,140 Region Association: None
Put me down for a set, Thanks
| dlee6204 |
Nov 16 2016, 02:34 PM
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
1set
| sdthomas |
Nov 16 2016, 02:39 PM
Member ![]() ![]() Group: Members Posts: 65 Joined: 14-June 11 From: Seattle Member No.: 13,193 Region Association: Pacific Northwest
I'll take one set!
| brownaar |
Nov 16 2016, 04:41 PM
Member ![]() ![]() Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None |
1 set, please!
| Mikey914 |
Nov 17 2016, 01:28 AM
PMs sent to all
| TX914 |
Nov 17 2016, 08:51 AM
Alan-B ![]() ![]() Group: Members Posts: 177 Joined: 27-July 14 From: USA Member No.: 17,689 Region Association: None
I'll take a set. Thanks.
| porbmw |
Nov 17 2016, 09:07 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 818 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None
I'm sure that my daughter's car will need one...and I probably do as well.
Two, please |
| pgollender |
Nov 17 2016, 09:16 AM
Member ![]() ![]() Group: Members Posts: 201 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California |
A set for me too Mikey !
| ndfrigi |
Nov 17 2016, 10:16 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
Sir Mike one set for me too.
| iankarr |
Nov 17 2016, 04:48 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,595 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
I never even knew those existed! 1 set for me please.
| JeffBowlsby |
Nov 17 2016, 07:59 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,222 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
I'm in for a set of the silicones. Let me know.
| 914Sixer |
Nov 17 2016, 09:14 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,453 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
I will take a set. Is there an update on the CHT senders or did I miss it?
| rgolia |
Nov 18 2016, 01:54 PM
GeoJoe ![]() ![]() ![]() Group: Members Posts: 720 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States
one set for me.....
Lo-Fi Version | Time is now: 2nd April 2026 - 11:04 AM |
