| ricardo |
Nov 17 2016, 06:59 AM
Newbie ![]() Group: Members Posts: 47 Joined: 9-November 16 From: Lakeview, NY Member No.: 20,572 Region Association: North East States |
I finally got my '74 1.8 engine started. Seems to be spewing white smoke Also, when I connect vacuum hoses to the decel. valve the engine stalls.
I wonder if I need this valve? also if I eliminate the valve I can't just plug the hoses because, again, the engine will stall. (IMG:style_emoticons/default/WTF.gif) |
| jim_hoyland |
Nov 17 2016, 07:21 AM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,028 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
I finally got my '74 1.8 engine started. Seems to be spewing white smoke Also, when I connect vacuum hoses to the decel. valve the engine stalls. I wonder if I need this valve? also if I eliminate the valve I can't just plug the hoses because, again, the engine will stall. (IMG:style_emoticons/default/WTF.gif) I went through this many mon ago; When I removed the decal on my '75 L-Jet, we used rubber corks and inserted on into the plenum nipple and a second one into the boot orifice/nipple. And, removed the small vac line. Sound like you may have an air leak there or on another connection. Be carefull; sometimes a hose looks good, or a Y connector is holding; but closer inspection/testing reveals cracks.... (IMG:style_emoticons/default/smile.gif) |
| timothy_nd28 |
Nov 17 2016, 09:17 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest
Can you post a picture of your engine bay?
| Porschef |
Nov 18 2016, 05:44 AM
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,180 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States
Make sure that the hoses aren't switched.
| ricardo |
Nov 18 2016, 09:46 AM
| ricardo |
Nov 27 2016, 12:24 PM
Well, it's been many days and a lot of fiddling with ignition and fuel and i'm still no closer to solving my problem.
Car will only run when I disconnect the decel valve and don't plug the hoses. Also, white smoke. I'm a patient person but i'm just about at the end of my rope! |
Lo-Fi Version | Time is now: 3rd March 2026 - 05:29 AM |
