Flywheel and pressure plate clean up, Media blasting an option? |
toadman |
Nov 20 2016, 04:56 PM
Member Group: Members Posts: 168 Joined: 26-December 05 From: Cincinnati, OH Member No.: 5,316 |
I have a couple of flywheels and pressure plates that are kind of rusty. Is there a good way to clean them up? Is media blasting an option?
Thanks |
lonewolfe |
Nov 20 2016, 05:03 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
mb911 |
Nov 20 2016, 05:16 PM
914 Guru Group: Members Posts: 6,876 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I have a couple of flywheels and pressure plates that are kind of rusty. Is there a good way to clean them up? Is media blasting an option? Thanks Good question! I'd like to know this as well. I'd also like to know the same for brake rotors. I blast flywheels and rotors and then have them zinc plated.. I have for years on all my cars.. It works perfect and costs almost nothing.. Never did a pressure plate but I would think it would be fine.. Here is a picture of my flywheel |
mb911 |
Nov 20 2016, 05:17 PM
I have a couple of flywheels and pressure plates that are kind of rusty. Is there a good way to clean them up? Is media blasting an option? Thanks Good question! I'd like to know this as well. I'd also like to know the same for brake rotors. I blast flywheels and rotors and then have them zinc plated.. I have for years on all my cars.. It works perfect and costs almost nothing.. Never did a pressure plate but I would think it would be fine.. Here is a picture of my flywheel Attached thumbnail(s) |
rgalla9146 |
Nov 20 2016, 06:33 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Flywheel yes, pressure plate no.
You'll never get the grit out of the moving parts and it will most likely affect smooth action. Wash it. |
bdstone914 |
Nov 20 2016, 07:41 PM
bdstone914 Group: Members Posts: 4,534 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Flywheel yes, pressure plate no. You'll never get the grit out of the moving parts and it will most likely affect smooth action. Wash it. (IMG:style_emoticons/default/agree.gif) Another reason is that zinc plating can produce hydrogen embrittlement that could lead to the fingers on the plate breaking off. Hardeded fasteners are baked 4 -8 hours if plated to drive out the hydrogen. |
bdstone914 |
duplicate
N_Jay |
Nov 20 2016, 08:08 PM
Member Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
On the flywheel, does the plating affect the contract surface, or do you have that machined afterwards?
bdstone914 |
Nov 20 2016, 08:13 PM
On the flywheel, does the plating affect the contract surface, or do you have that machined afterwards? It would come off the first time the clutch is engaged. Rotors are commonly zinc plated on the working surface with no ill effects. But there is no good reason to do it. |
mb911 |
Nov 21 2016, 08:46 AM
On the flywheel, does the plating affect the contract surface, or do you have that machined afterwards? It would come off the first time the clutch is engaged. Rotors are commonly zinc plated on the working surface with no ill effects. But there is no good reason to do it. I zinc plate because the none contact areas don't rust as quickly.. It's kind a preferred taste. For me |
Lo-Fi Version | Time is now: 6th June 2024 - 11:35 AM |
