| Gunn1 |
Nov 24 2016, 10:18 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
I looked back (did a search) trying to locate a ready made set up that would replace the old clutch cable stuff and replace it with a Hydraulic/slave cylinder configuration. I found a few photos and a few posts saying there would be a kit forthcoming, but up to this point I haven't come across it. (IMG:style_emoticons/default/confused24.gif) Also saw a "hydraulically" actuated throw-out bearing. (IMG:style_emoticons/default/confused24.gif) This would be for a stock 75' 2 liter and tranny.
Also want to keep the pedal locations stock (I'm tall) the car also has the front and rear sway bars. Even more importantly does anyone have experience with either set up. Any thoughts or pointers in the right direction would be great. |
| GeorgeRud |
Nov 24 2016, 09:34 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Don't think anyone offers a bolt-in kit, though several folks have done this conversion. The hard part seems to be fitting the clutch master cylinder. If a kit would become available, I think many folks would be interested to get rid of the clutch cable.
| porschetub |
Nov 25 2016, 12:14 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I just don't see the point unless you have V8 conversion or similar with a big heavy clutch,not an easy conversion...and yes no kits out there cause there is little or no interest.
| mb911 |
Nov 25 2016, 11:34 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,694 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
I desperately need something like this for dad's car along with some sort of button operated actuator as my dad can't push in the clutch very well any more
| porschetub |
Nov 25 2016, 12:26 PM
Fair enough , sorry didn't know of your needs.
| jmill |
Nov 25 2016, 12:42 PM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
The auto stick bugs did it with vacuum. There was a switch in the stick shift handle that actuated clutch when you pressed down and also when you pressed brake.
| shoguneagle |
Nov 25 2016, 01:11 PM
shoguneagle ![]() ![]() ![]() Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
The hydraulic clutch was done years ago by "a914guy" using a CNC slave cylinder and a master cylinder from a 928 Porsche (if I remember correctly). The hydraulic lines and fittings were 3AN size. The line does go through the tube before fitting attachments.
The most complicated factor is welding a mounting plate onto the underside of the body next to the brake master cylinder; then set the arm length from the clutch to the master cylinder (rod does attach to the pedal arm without too much trouble.) Add a reservoir to the top next to the hydraulic one and run a line down and attach. The bottom right side of the transmission with a makeup bracket to hold the one end of the slave cylinder and the other one attaches to the clutch yoke arm using the existing metal shift cable wedge. I think you will find the details either by contacting "a914guy", a search under hydraulic clutches, or getting me off my old dead ass and take some photos. This example is one of the only ones that you can get details to where you can use the ideas to build your own. I built A914GUY's hydraulic clutch which is on my car. I used Wilwood slave cylinder #620-1033 and matched the shorty Wilwood master cylinder to it. Make sure you match the bore sizes as recommended by the manufacturer. (Something like 3/4 inch master; 7/8 inch slave). Hope this helps you. Steve Hurt |
| Mikey914 |
Nov 25 2016, 01:16 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Look at the 944 / 951 this is a stock set up. May be able to easily adapt.
| Gunn1 |
Nov 25 2016, 02:05 PM
| amfab |
Nov 25 2016, 03:15 PM
Member ![]() ![]() Group: Members Posts: 401 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None
this place is awesome
| Gunn1 |
Nov 25 2016, 03:45 PM
| mgp4591 |
Nov 25 2016, 04:35 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,832 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region
I desperately need something like this for dad's car along with some sort of button operated actuator as my dad can't push in the clutch very well any more You may want to increase the leverage on the cable roller assy. by replacing it with a lever instead of a roller. It takes a little engineering but it works. Rnellums did a similar arrangement with his trans even though its a Subaru trans - it works really well. Lessening the effort makes it easier for him to push=better driveability for him. |
| Mikey914 |
Nov 25 2016, 04:46 PM
With the hydraulic the piston size is close to 1/1 so you probably have plenty of force in the stock 944 / 951 set up. The engineering is done, just a matter of mounting. That's why I recommended this as the 951 clutch is actually pretty beefy from the factory. The torque tube setup makes is undesirable to have to change often.
| mb911 |
Nov 25 2016, 05:01 PM
I desperately need something like this for dad's car along with some sort of button operated actuator as my dad can't push in the clutch very well any more You may want to increase the leverage on the cable roller assy. by replacing it with a lever instead of a roller. It takes a little engineering but it works. Rnellums did a similar arrangement with his trans even though its a Subaru trans - it works really well. Lessening the effort makes it easier for him to push=better driveability for him. That's not a bad idea. If it were very easy he could do it.. |
| Mark Henry |
Nov 25 2016, 05:49 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Someone else did it with VW vanagon parts.
Hard part is fab the mounts, but that said what I've seen they're pretty simple. |
Lo-Fi Version | Time is now: 7th December 2025 - 09:51 AM |
