| carcus |
Nov 26 2016, 10:41 PM
Member ![]() ![]() Group: Members Posts: 223 Joined: 16-March 16 From: Colorado Springs Member No.: 19,760 Region Association: Rocky Mountains |
Curious, my earlier 914 had the jack assist points on the side of the rockers, my 1976 has the OEM steel ones without the square jack pad holes. Did they do away with the jack assist points on the later model or are they still under there if the rockers are removed?
| SirAndy |
Nov 27 2016, 12:00 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,453 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Jack Assist Points?
(IMG:style_emoticons/default/confused24.gif) |
| carcus |
Nov 27 2016, 12:20 AM
The ones on the lower door panel rockers that a square jack assist can slide in. |
| SirAndy |
Nov 27 2016, 12:27 AM
Ok, now i'm completely confused. There is only one type of jack post on a 914.
They all accept the square jack. (IMG:style_emoticons/default/popcorn[1].gif) |
| SixerJ |
Nov 27 2016, 01:55 AM
Member ![]() ![]() Group: Members Posts: 451 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
Andy, I think he means that his rocker covers don't have holes? Which also means the jack point would have been cut back
To Andy's point, yes all 914s regardless of year came with the jack point, plus a hole in the rocker cover & plastic plug in the hole Sounds like your car has been modified or not repaired properly in the past Pictures please |
| cary |
Nov 28 2016, 12:30 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
| iwanta914-6 |
Nov 28 2016, 10:14 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 718 Joined: 26-June 09 From: Minnesota Member No.: 10,510 Region Association: None
If you don't have a square hole in your "OEM" steel rocker panels, then they are not OEM. I'm guessing there was some rust around the jack points and they were removed when the longs were repaired. Maybe the hole in the rocker was patched?
Lo-Fi Version | Time is now: 3rd March 2026 - 08:36 PM |
