> Troble with wrench fit, On front calipers
PanelBilly
post Nov 27 2016, 01:36 PM
Its time to bleed my brakes and freshen up the fluid. Back calipers are easy, but fronts are a pain. I'm using the self bleeding screws and there isn't enough room to get a box wrench around the screw. The open end is too tight to fit securely too. I'm looking for a thin 8mm box wrench but all I find is thin open ends. What are the rest of you using?
McMark Edit: caliber -> caliper
Replies(1 - 12)
Elliot Cannon
post Nov 27 2016, 01:39 PM
Group: Retired Members
QUOTE(PanelBilly @ Nov 27 2016, 11:36 AM) *
Its time to bleed my brakes and freshen up the fluid. Back calibers are easy, but fronts are a pain. I'm using the self bleeding screws and there isn't enough room to get a box wrench around the screw. The open end is too tight to fit securely too. I'm looking for a thin 8mm box wrench but all I find is thin open ends. What are the rest of you using?
Buy a cheap wrench and grind it down to fit.
messix
post Nov 27 2016, 01:42 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
find one of these http://www.parktool.com/product/metric-flare-wrench-mwf-1
a flair nut wrench
11tenths
post Nov 27 2016, 01:51 PM
Ve get too soon old, und too late schmart
I always try to break the bleeders free with a deepwell 6pt socket first, then use 'mini' (ignition) wrenches to perform the bleeding duties.
-Harry
cary
post Nov 27 2016, 04:42 PM
Second on 6 pt. no matter which tool you choose.
Very soft material.
914Sixer
post Nov 27 2016, 06:57 PM
Are you SURE someone did not switch bleeders with SAE fittings? Try a good ole American size next.
PanelBilly
post Nov 28 2016, 12:10 PM
the issue isn't the fit of the screw but it's the amount of space to fit a box wrench or an open end around the screw because the casting of the case is so close to the screw.
rjames
post Nov 28 2016, 01:13 PM
I'm made of metal
I don't remember having any issues getting a craftsman box wrench in there when I bled mine.
wndsnd
post Nov 28 2016, 01:16 PM
You wanted a horse, but got a goat. Nobody wants a goat....
Second on ignition wrenches
McMark
post Nov 28 2016, 01:35 PM
914 Freak!
QUOTE(PanelBilly @ Nov 28 2016, 01:10 PM) *
Yes, but stock bleeders are 7mm, not 8. So if you've got 8mm bleeders, something was changed and now you have less clearance.
sixnotfour
post Nov 28 2016, 02:26 PM
flare nut wrench is way to beefy, just get a brake bleeding wrench,, but if your bleeders are wrong it may not help,,
http://www.sears.com/abn-offset-brake-blee...p;blockType=G1#
whitetwinturbo
post Nov 28 2016, 11:10 PM
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif)
JeffBowlsby
post Nov 28 2016, 11:37 PM
Seems to me the speedbleeders are 8mm. I use them and a standard craftsman 8mm box end wrench...no issues.
- Lo-Fi Version Time is now: 29th April 2026 - 11:11 PM
