> Fuel filter needs clamps?
coupelover
post Dec 5 2016, 10:40 PM
Own a 74 2.0. Replacing the fuel filter. Current one has no hose clamps and diagram on web shows no hose clamps. Just want to make sure I don't need them since these cars are already fairly flammable.
Replies(1 - 10)
boxsterfan
post Dec 5 2016, 10:43 PM
914's are kewl
*Deleted
mark04usa
post Dec 5 2016, 10:44 PM
'70 1.7 Tangerine
Most definitely use good quality high pressure style hose clamps!
porschetub
post Dec 6 2016, 12:52 AM
Use approved fuel line band clamps,not screw thread clamps,they cut into the hose and put you and yours in risk...ok.
Boxterfan ,honestly that was a numb nuts reply really...come on.
Mark Henry
post Dec 6 2016, 07:00 AM
that's what I do!
QUOTE(porschetub @ Dec 6 2016, 01:52 AM) *
You need the proper size fuel injection hose clamp, IIRC there are two different sizes on the pump and filter, many FLAP sell an assortment kit.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.ratwell.com-26-1481029530.1.jpg)
VW used the push-on no clamp braided hose on carb and I believe they may have done this on the low pressure side of FI systems. The cloth braid available from VW shops sucks quality wise and will totally self destruct if you use ethanol gas.
Any aftermarket hose must have a clamp.
BTW the only hose I use without clamps is Parker Push Lok (matching hose and fitting) for oil lines.
coupelover
post Dec 6 2016, 09:09 AM
Perfect. Thanks for the response. Helpful as always.
boxsterfan
post Dec 6 2016, 12:37 PM
914's are kewl
QUOTE(porschetub @ Dec 5 2016, 10:52 PM) *
*deleted
TheCabinetmaker
post Dec 6 2016, 04:26 PM
I drive my car everyday
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/stromberg.gif)
bandjoey
post Dec 6 2016, 06:40 PM
bandjoey
QUOTE(boxsterfan @ Dec 6 2016, 12:37 PM) *
You'll catch on to the trolls posting here eventually. Go re-read the ridiculous post. You will find many like it on the board.
From the keyboard of Mark:
VW used the push-on no clamp braided hose on carb and I believe they may have...
So it's possible (IMG:style_emoticons/default/popcorn[1].gif)
boxsterfan
post Dec 6 2016, 09:02 PM
914's are kewl
QUOTE(bandjoey @ Dec 6 2016, 04:40 PM) *
Fair enough.... I deleted my comments above.
Mark Henry
post Dec 6 2016, 10:58 PM
that's what I do!
QUOTE(bandjoey @ Dec 6 2016, 07:40 PM) *
Don't take me as gospel on the FI low pressure side having no clamps, I'm not 100% on that.
But on carb cars like the type one engined beetle, bus and T3, using OE german braided hose I am 100% sure VW never used hose clamps of any type. Pushed on far enough you couldn't get the hose back off without cutting it. Did this for years, never an issue.
I no longer use this hose as I see it cracking in as little as one year even with pure gas. Haven't seen a failure do to this cracking, but I'm taking no chances.
Now I only use SAE 30R9 even for carbs.
- Lo-Fi Version Time is now: 11th March 2026 - 11:26 PM
