| StratPlayer |
Dec 6 2016, 11:44 AM
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,357 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains
I think this is something a lot of folks could use.... hoping you can reproduce these units.
http://www.914world.com/bbs2/index.php?sho...=trunk&st=0 |
| McMark |
Dec 6 2016, 11:56 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
| Mark Henry |
Dec 6 2016, 11:57 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I don't have the engman unit, but I have an earlier one, may even be homemade using bicycle cable. One thing I'd suggest is mounting in the engine compartment, shorter run means less issues, even if a bit of a PITA opening your engine lid all the time.
Also an issue I have is the lid not popping enough to clear the lock mechanism. I am going to reengineer the way it pops open. |
| StratPlayer |
Dec 6 2016, 12:53 PM
I've had the engman kit installed on my car for about 13 years, haven't had any problems with it since it was installed. I have my hands on another kit that I picked up hell I don't know when. Thinking this kit may go to Jim Hoyland.
Attached thumbnail(s) |
| Steve |
Dec 6 2016, 01:14 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,025 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
I installed a spal solenoid and tied it to the alarm remote. A lot less hastle than a cable.
https://www.amazon.com/gp/product/B009OBPHS...=UTF8&psc=1 |
| Mikey914 |
Dec 6 2016, 04:06 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Yes i had been looking at these making an option for electric with a manual overide. Just in case.
| Kansas 914 |
Dec 6 2016, 04:55 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,006 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains
Yes i had been looking at these making an option for electric with a manual overide. Just in case. (IMG:style_emoticons/default/agree.gif) When I had a reflector on my car I always had a mechanical over ride. I used it more often then the solenoid since it usually took two people with the electric release. |
| jim_hoyland |
Dec 6 2016, 07:22 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,033 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
I've had the engman kit installed on my car for about 13 years, haven't had any problems with it since it was installed. I have my hands on another kit that I picked up hell I don't know when. Thinking this kit my go to Jim Hoyland. That what I need, thanks for digging it up |
| StratPlayer |
Dec 6 2016, 08:02 PM
Ok jim I'll get it off to you ASAP<
| Steve |
Dec 7 2016, 11:55 AM
Yes i had been looking at these making an option for electric with a manual overide. Just in case. (IMG:style_emoticons/default/agree.gif) When I had a reflector on my car I always had a mechanical over ride. I used it more often then the solenoid since it usually took two people with the electric release. I had the same problem with the wimpy solenoid that came with the kit. That spal solenoid is very beafy and solved that problem. I also drilled an 1/8" hole at the top of the "S" in the reflector for emergencys. |
Lo-Fi Version | Time is now: 10th March 2026 - 06:49 AM |
