tazz9924 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 743 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None ![]() |
I was told the other day that 944 cvs can be modified for stock stub axles. i understand they're a bit thicker and requires machining to get them to fit on the axle but, how close are the bolt holes and what is required to get them to fit on the stub (i only have to worry about the outer cv as i have subaru inners)
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,284 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
I was told the other day that 944 cvs can be modified for stock stub axles. Not exactly ... http://www.914world.com/bbs2/index.php?showtopic=80641 (IMG:style_emoticons/default/smile.gif) |
North Coast Jim |
Member ![]() ![]() Group: Members Posts: 340 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region ![]() ![]() |
I was told the other day that 944 cvs can be modified for stock stub axles. i understand they're a bit thicker and requires machining to get them to fit on the axle but, how close are the bolt holes and what is required to get them to fit on the stub (i only have to worry about the outer cv as i have subaru inners) Porsche just re-released the entire axle shaft for our 914's. I bought 2 of them and are now installed in the car. No need to look for work a work around. Cost by the way was $300/each |
Lo-Fi Version | Time is now: 1st August 2025 - 03:43 PM |
