Rear sway bar link bushings |
tomh |
Dec 11 2016, 08:06 PM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
I am changing out the bushings on the rear sway bar links. It seems the shock bolt with the ball on it will not slide out without removing the heat exchanger, I want to avoid doing that. What's the best way to press on the link to the shock mount.
raynekat |
Dec 11 2016, 09:12 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Something like these? BigAzz (for real) channel locks.... |
914Sixer |
Dec 12 2016, 07:09 AM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
C-Clamp is smooth and easy pressure.
PlaysWithCars |
Dec 12 2016, 11:18 PM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
C-Clamp is smooth and easy pressure. (IMG:style_emoticons/default/agree.gif) Been there, done that. Started with a rubber BFH (big f&*^%$#g hammer) and eventually got it on. But the next time I needed to do the job I used a big c-clamp. Much easier. |
porschetub |
Dec 13 2016, 12:59 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I had difficulty,found it better if I attached the drop links first to the bar,once these were on I dropped one body mount down a little and pressed them on to the shock bolts.
All this done with a small "g" clamp for the drop links and a large one for the shock bolts. Still wondering if I need a rear swaybar anyway (IMG:style_emoticons/default/idea.gif) . |
Racer |
Dec 13 2016, 04:49 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
fwiw, I found it much easier to install without the wheel on the car (especially little 14" wheels as I couldn't get enough purchase to squeeze droplink onto the shock bolt.) C-Clamp worked great.
tomh |
Dec 15 2016, 09:19 AM
Got the bushings in last night, major PITA. Used BFH c -clamp and big channel lock and of course Vaseline.I looked like a monkey trying to screw a bowling ball but I got it.
Lo-Fi Version | Time is now: 5th June 2024 - 10:27 PM |
