'75 Dash Facing, left side only, Question re facing material.... |
jim_hoyland |
Dec 12 2016, 04:53 PM
Get that VIN ? Group: Members Posts: 9,317 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I'm going to enlarge the fog light switch hole; ignition switch will be installed there . Question is can I remove the left side dash face without pulling the steering assembly. I've read that the late (75 - 76 ) dash faces differ from earlier years. Currently the dash face is covered with leather.
Picture shows the area; not using the 911 switch, but plan to use sixnotfour's modified 914 switch. Attached image(s) |
whitetwinturbo |
Dec 15 2016, 01:06 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
sixnotfour |
Dec 15 2016, 04:47 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
The 76 piece ,is very flexible ,,I made a pilot hole , then pulled it away and enlarged the hole to what I liked..scary stuff ..
Attached image(s) |
sixnotfour |
Dec 15 2016, 04:58 PM
this was the first trim , I have since enlared it more like on OG six.
Jim, its way easiest to doit all at once.. (IMG:style_emoticons/default/beerchug.gif) Attached image(s) |
Mikey914 |
Dec 16 2016, 02:15 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
As you can see from the metal, unless you cut it (which you could do) you would have to do at one time. I think you could do it.
The early, late and the one we make shown Attached thumbnail(s) |
jim_hoyland |
Dec 16 2016, 03:50 PM
Lo-Fi Version | Time is now: 6th June 2024 - 06:46 AM |
