Window adjustments, Is there a thread I can't find |
North Coast Jim |
Dec 13 2016, 03:24 PM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Replaced all the rubber on the car with Mikey's 914 Rubber components. Car is a '74 2 liter with late doors. After assembling all the rubber and door components I can't seem to get the window adjusted to keep the top rear from impinging with the Targa seal. It sticks and needs me to push to get it started. Working with the Haynes manual and have taken all the adjustments I can. I see that there is a bit of space in the triangular window, at the top, that if removed should allow the needed gap for the wind up window. It's winter here and even though my garage is heated I can't seem to move the seals on the triangle window. Do I have to wait until the heat of summer to soften up the seals to get them to move the distance required ?? I've attached a couple of pics but don't know if they show the gap in sufficient detail.
rhodyguy |
Dec 13 2016, 03:49 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,089 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
window adj is on the bottom front of the door. p205 fig 10.42 of your haynes for details.
Mikey914 |
Dec 14 2016, 01:03 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
This may be of help post 21 has manual pics
http://www.914world.com/bbs2/index.php?sho...window+seal+B.B |
North Coast Jim |
Dec 14 2016, 08:13 AM
This may be of help post 21 has manual pics http://www.914world.com/bbs2/index.php?sho...window+seal+B.B Thanks Mikey I knew there was a thread out there somewhere. I think my issue is that I have not controlled the triangle window location properly allowing it to ride up the seal/track when I installed it into the door. Evidence that the top molded piece with the two screws holding it does not fit well - it's raised in relation to the top of the chrome window guide. Need to tear it back down to that point and use your method of wrapping tape to control it's location. Doing it by hand WILL NOT locate it properly. Well off to the garage ......................... (IMG:style_emoticons/default/evilgrin.gif) |
rgalla9146 |
Dec 14 2016, 08:54 AM
Advanced Member Group: Members Posts: 4,564 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Did you remove the aluminum holder that attaches to the windshield column ?
It looks a bit raised off the column surface and protruding toward the roof, possibly causing interference. |
Lo-Fi Version | Time is now: 5th June 2024 - 01:03 AM |
