WTB: 914 901 differential, Need to make a tool |
BillC |
Dec 20 2016, 10:50 AM
Senior Member Group: Members Posts: 546 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
Edit: I got one, case closed.
--------------------------------- I'm rebuilding a side-shift 901 out of a '74 914. Since the bearings need to be replaced, I need to check pinion depth to ensure it's done properly. However, the factory tool for checking that is $$$$ and very difficult to find. So, I'm going to make my own (already have mill and lathe). I'd like to buy a differential from a 914 901 box. It doesn't actually have to be from a 914 trans, but it does need to be from a magnesium case trans. I don't need the ring gear or spider gears, just the diff housing (but I would like the roller bearings and spacers, if possible). Anyone have one lying around that's in decent shape, just taking up space? Thanks! |
fduval |
Dec 20 2016, 11:58 AM
Newbie Group: Members Posts: 41 Joined: 2-January 13 From: quebec Member No.: 15,331 Region Association: Canada |
I'm rebuilding a side-shift 901 out of a '74 914. Since the bearings need to be replaced, I need to check pinion depth to ensure it's done properly. However, the factory tool for checking that is $$$$ and very difficult to find. So, I'm going to make my own (already have mill and lathe). I'd like to buy a differential from a 914 901 box. It doesn't actually have to be from a 914 trans, but it does need to be from a magnesium case trans. I don't need the ring gear or spider gears, just the diff housing (but I would like the roller bearings and spacers, if possible). Anyone have one lying around that's in decent shape, just taking up space? Thanks! Hi Bill I think I have what you need see picture attached .. Contact me if it works for you . regards Francois |
colingreene |
Dec 20 2016, 03:39 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
i also have several.
sixaddict |
Dec 20 2016, 04:34 PM
Senior Member Group: Members Posts: 805 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Bill
Pretty sure I have one under a bunch of stuff Cannabilized a bunch of gears to rebuild a box but didn't need the other parts Since I am in South Carolina may save you some shipping $$ Your call Terry |
Lo-Fi Version | Time is now: 3rd June 2024 - 05:31 AM |
