Thanks 914club and Demick!, Fog light wiring was a success |
ChrisReale |
Jun 26 2003, 08:51 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Thanks to the club who hosts the info, and demick for writing it up. It was very easy to do. (IMG:style_emoticons/default/smilie_pokal.gif)
Bleyseng |
Jun 26 2003, 09:02 PM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Great, you'll be able to use them for the next Autocross when its raining.
Geoff |
ChrisReale |
Jun 26 2003, 09:37 PM
QUOTE(Bleyseng @ Jun 26 2003, 08:02 PM) Great, you'll be able to use them for the next Autocross when its raining. Geoff Yea.... (IMG:style_emoticons/default/sad.gif) |
Bruce Allert |
Jun 26 2003, 09:42 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
Chris, do ya still have yer high beam indicator lite? I switched the wrong 2 wires & lost mine. Fogs work independent but no blue lite. Gotta do dat sum dey!
bruce |
ChrisReale |
Jun 26 2003, 09:44 PM
I dont think me high beams even work, but I think I did loose the indicator. Oh well.... (IMG:style_emoticons/default/blink.gif)
Bleyseng |
Jun 26 2003, 10:03 PM
You guys are ahead of me, my fogs still don't work.
Geoff |
Bruce Allert |
Jun 26 2003, 11:47 PM
Me thinks the 3 of us should get together & do fogs & syncros... what say ye???
bruce |
Dave Cawdrey |
Jun 26 2003, 11:57 PM
Dumbo going poop, Daddy :) Group: Members Posts: 818 Joined: 22-January 03 From: Seattle, WA USA Member No.: 182 |
me thinks me lonely... (IMG:style_emoticons/default/sad2.gif)
Demick |
Jun 27 2003, 08:38 AM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
You should not lose your high beam indicator light. If you did, then the problem was with the conversion step #2.
If your car is a '70 or '71 4 cyl, then you probably followed the instructions for another year and used the wire from the fuse panel instead of the combination relay. If your car is a '72 or '73 4 cyl or a -6, then you used the wrong white/blue wire from the #1 fuse (there are 2 attached at the same point, and you need to figure out which is which). If your car is a '74 - '76, then you also used the wrong white/blue wire from the #1 fuse. There is actually a white/blue wire attached to each side of the #1 fuse. You need to select and ground the one that was attached to the input side (toward the rear of the car) of the #1 fuse. If you chose the wire from the output side (toward the front of the car) of the #1 fuse, then you grounded the high beam indicator and did not do anything to affect the fog light operation. I need to be more clear about this in the instructions, so I will get them updated. Sorry about any confusion. Demick '74 2.0 |
Bruce Allert |
Jun 27 2003, 09:11 AM
I know which wires they are now and just have to take 10 min. to make the switch. (just call me a procrastinator!) (IMG:style_emoticons/default/cool.gif)
bruce |
ChrisReale |
Jun 27 2003, 12:56 PM
I just checked and I still have my indicator light. (IMG:style_emoticons/default/smilie_pokal.gif)
Bruce Allert |
Jun 27 2003, 01:03 PM
Lo-Fi Version | Time is now: 23rd May 2024 - 12:47 PM |
