nsyr |
Because I Can ![]() ![]() Group: Members Posts: 314 Joined: 16-May 04 From: Tampa, FL Member No.: 2,073 ![]() |
I have a 72 with a fresh rebuilt 2.0 that I can't get to turn over. It does turn over good with the plugs out but when i put them in it stops on any given compression stroke. The starter is new, the cables are new (short 4 gauge), and the battery is good. The engine turns by hand but is a little stiff when opening valves (plugs out). Could it be that the valve adjustment is done wrong causing extra resistance? I know the cam-crank timing is right. I am at a lost right now and i need help (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
double check the valve adjustement. put in the plugs but take off the plug wires (no spark) and see if that makes a difference ofr the better, if so, the timing is completely off ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
nsyr |
When i had the plugs in the wires were not connected. The fuel isn't hooked up either so it can't be timing. Right now i am just trying to turn it over before trying to start it.
SirAndy |
you got heavier (or double) valve springs? i can't turn my engine over by hand (dual springs) ...
i'd check the valves first ... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Andy |
Lo-Fi Version | Time is now: 11th June 2024 - 01:49 AM |
