Cylinder/case seal. |
Keith914 |
Jan 4 2017, 11:26 AM
Member Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
My recently rebuilt Type IV is leaking oil between the cylinders and the case. This engine is now a 2.4 L (was 1.7) with no gaskets or shims between the cylinders and the case -- common practice. So what is the best sealant and best method of application?
McMark |
Jan 4 2017, 11:29 AM
I use Loctite 518 there. Applied with an acid brush. If it squeezes out the sides, you used WAY too much.
colingreene |
Jan 4 2017, 11:56 AM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
that^
that said i know fat uses 1211 |
injunmort |
Jan 4 2017, 12:25 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
hylamar blue
iankarr |
Jan 4 2017, 03:23 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
old tried and true permatex aviation. Jake uses it in his video, but that was admittedly a long time ago (IMG:style_emoticons/default/wink.gif).
IronHillRestorations |
Jan 4 2017, 07:35 PM
I. I. R. C. Group: Members Posts: 6,727 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I used the lower cylinder sealing rings on the few type IV's I've built. Could be the sealing surface of the case has dropped a little, I could see where sealant would be beneficial.
Mark Henry |
Jan 5 2017, 11:43 AM
Could be the sealing surface of the case has dropped a little... Every engine I build I now see the deck out .002-.005. These are 40+ year old cases (IMG:style_emoticons/default/shades.gif) |
forrestkhaag |
Jan 5 2017, 03:14 PM
Yamabond 4 is my engine-builder pal's choice and notes that in his race experience, it holds up in cylinder to case applications that see 10K rpms regularly. This goo is a silicone based liquid gasket that fills gaps on a flange surface and prevents leaks. When cured, this product forms a rubber-like body that resists heat and seals joints subjected to high temperature. It is gear and engine oil resistant, Yamabond 4 Motorsports sets in 60 minutes so you have time to work with it if chasing rings etc.
(IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
Keith914 |
Jan 5 2017, 05:36 PM
Thanks for all the advice. Yamabond it will be (IMG:style_emoticons/default/beerchug.gif)
Mark Henry |
Jan 6 2017, 01:20 PM
Lo-Fi Version | Time is now: 5th June 2024 - 04:23 PM |
