rich johnson's linkage Infor, Need help please |
forrestkhaag |
Jan 7 2017, 02:42 PM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
Does anyone have a link to Rich Johnson's 6 conversion linkage kit? I have the pieces but have missplaced the install diagrams etc. / tap sizes and locations etc? Please pm me asap if you have anything to keep me up on the lift today. thanks
mepstein |
Jan 7 2017, 03:11 PM
914-6 GT in waiting Group: Members Posts: 19,283 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
It should just bolt on. No tap needed.
porschetub |
Jan 7 2017, 03:32 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Thought there was a bolt to be tapped into the gearbox,8mm was what I did but I didn't use a bracket,mounted my cable holder on the clutch roller bracket.
Pic shows bolt on RJ's kit. Drill this hole in the casing with caution and makes sure you don't drill too deep,good luck. |
914Sixer |
Jan 7 2017, 03:53 PM
914 Guru Group: Members Posts: 8,887 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Unless the transmission is a early tailshifter the hole is not tapped. Thinking only the 1970 and may be early 1971 had hole with bolt installed.
mepstein |
Jan 7 2017, 05:03 PM
I thought rich's kit could be bolted on to the trans with the black adapter. Otherwise you might as well just tap the trans intermediate plate and use the bellcrank without the adaptor. Might as well ask rich and get the facts.
Steve |
Jan 7 2017, 05:10 PM
914 Guru Group: Members Posts: 5,596 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Mine was bolt on, but I had to modify it for the current 915 trans.
mepstein |
Jan 7 2017, 05:28 PM
shoguneagle |
Jan 8 2017, 01:31 AM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
I have Rich's accelerator kit on my late 914 transaxle; it had a drilled port and stud installation for the rear mounting; two other studs on the right side where used to mount the front half; do not have any information available now; etc.
Contact Rich and he may send you the information; if needed, I can measure the stud, where it is located, drill size, etc. |
mlindner |
Jan 8 2017, 07:27 AM
Senior Member Group: Members Posts: 1,522 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
I have Rich's bellcrank set up. Also had to call Rich as to install, drilled, tapped....very easy, very prompt...Rich is the best. Mark
mlindner |
Jan 8 2017, 09:34 AM
IronHillRestorations |
Jan 8 2017, 12:59 PM
I. I. R. C. Group: Members Posts: 6,720 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
There's a round casting boss right where it should be drilled and tapped. I'd recommend NOT trying to do that by hand. I like to use a longer stud for the side cover.
flmont |
Jan 8 2017, 03:31 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
these kits still avaliable...?? for a 76' 901
mepstein |
Jan 8 2017, 04:22 PM
Steve |
Jan 8 2017, 06:55 PM
Lo-Fi Version | Time is now: 23rd May 2024 - 01:23 PM |
