'74 1.8 Gas smell in cabin and Fuel pump replacement |
branston |
Jan 14 2017, 10:06 PM
Member Group: Members Posts: 89 Joined: 17-October 12 From: Michigan Member No.: 15,053 Region Association: Upper MidWest |
Getting in the car last weekend the cabin stank of gas, the pump is leaking and dripping on the flexible heater pipe leading into cabin.
Pump seems to have been running okay looking at it I'm sure its been in there a long time. hard to tell if the hose is leaking and wetting the body of the pump. to me it looks like its leaking where the electrical connector enters the pump body. Is this a typical failure? the pump runs okay. Pump is out tonight and looking at the $$$ cost of a rebuilt pump I came across this post. http://www.914world.com/bbs2/index.php?sho...mp;hl=fuel+pump The replacement of the old 3 port pump with a new Bosch 69133 seems like a great solution, but here's my question, will the conversion work on the 1.8 engine in my '74? Just need to know before I dive in and buy one. |
Dave_Darling |
Jan 15 2017, 01:48 AM
The FI only cares about getting the right volume and pressure of fuel. So it doesn't matter which pump is supplying the fuel, as long as it supplies enough.
You eliminate the "Y" fitting in the return line. BTW, get proper fuel-injection hose clamps. The ones you have are designed to cut into the hose, which is not a good idea with high-pressure fuel hose. --DD |
ndfrigi |
Jan 15 2017, 03:03 AM
Advanced Member Group: Members Posts: 2,929 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
sir, just replace it with this type of fuel pump. Return line goes directly to the fuel tank to eliminate the y connection from that fuel pump who have now.
74ravenna |
Jan 15 2017, 04:18 AM
Member Group: Members Posts: 471 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States |
And while you're at it order new s.s. fuel lines from Tangerine and replace those old plastic lines.
branston |
Jan 15 2017, 07:16 AM
Thank-you for all the responses. A new style pump it is then. Along with stainless lines, new rubber hoses and the correct clamps.
Lo-Fi Version | Time is now: 23rd May 2024 - 06:42 AM |
