Gearbox issue |
Gearbox issue |
Redraptor |
Jan 18 2017, 02:23 PM
Newbie Group: Members Posts: 36 Joined: 18-October 16 From: Louisville, KY Member No.: 20,501 Region Association: MidAtlantic Region |
So I slowly but surely am taking my 914 apart and it is going well. However, while I was crawling around underneath today I noticed something that scared me a little. The ear of the gearbox used to connect the mounting has been sheared off leaving the transmission hanging by one side. From my limited knowledge it looks like the pieces can be welded back together.
My questions are as follows: 1)Would welding be good enough or for the price would I be better off buying one online? If I end up buying one is there a difference in years for the gearbox covers? |
brant |
Jan 18 2017, 02:26 PM
914 Wizard Group: Members Posts: 11,628 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
it can be welded
you need someone highly skilled in alloy it is a magnesium alloy not as flammable as pure magnesium but still requires a skilled welder all of the side shifts used the same rear tail cone 1973-1976 I think the going price is around 200? maybe slightly less |
wndsnd |
Jan 18 2017, 05:56 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Scout The Samba. A cheap housing might come up.
Good luck! |
stugray |
Jan 18 2017, 06:02 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Do you have a sideshift or tailshift?
I have a tailshift cone I never intend on using again |
mepstein |
Jan 18 2017, 07:28 PM
914-6 GT in waiting Group: Members Posts: 19,300 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Get a replacement part from someone here. If you ask nicely, you'll get it cheap and save the hassle of getting yours welded. Make sure you assemble it properly with the washers in the correct direction. It's a part that shouldn't normally break.
Redraptor |
Jan 19 2017, 05:53 AM
Thanks guys. I have a bunch of welders in my area, but I would prefer to get one that hasnt been broken. Im not in a big rush, but it freaked me out when I saw it. I was sliding myself under the car, without a dolly since I didnt jack it up high enough to use one rookie mistake, I was looking up and my light hit everything just right and I saw the sheared support. Anyway, I'm dropping the engine soon to clean it and get into restoring my new baby so this is really just one more stop on the journey.
It's a 2.0 74 with a sideshift. I've been able to find the tail shifts pretty quickly, but not so on the sides. |
mlindner |
Jan 19 2017, 06:33 AM
Senior Member Group: Members Posts: 1,523 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Redraptor, and if you replace it....good time to check or replace 1st/reverse slider and synhro ring, easy to get to. Best, Mark
Redraptor |
Jan 19 2017, 07:11 AM
Thanks. It has been sitting for 30 years so everything is a least getting looked at and thoroughly cleaned. She has pretty low mileage so Im not anticipating too much wear on the internals, but mice have managed to get stuff everywhere. Nasty. The gearbox issue is the first uh-oh moment I have had with the car.
PanelBilly |
Jan 19 2017, 08:02 AM
914 Guru Group: Members Posts: 5,810 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Good thing your dropping the engine. Look closely at the mount in the front while you've got it apart. With the engine being supported from three point for a while now, there was additional twisting done.
stugray |
Jan 19 2017, 08:10 AM
nevermind
Dr Evil |
Jan 21 2017, 09:35 PM
Not too bad to replace the tail cone if you left the engine in the car. Grease, patience, dexterity, swear words are your friends. Good call not to weld, its a pain and not worth it in the end. Cones are prevalent, I have several (I should, tho).
Rob-O |
Jan 21 2017, 10:42 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Not too bad to replace the tail cone if you left the engine in the car. Grease, patience, dexterity, swear words are your friends. Good call not to weld, its a pain and not worth it in the end. Cones are prevalent, I have several (I should, tho). What the???? Who is this guy? Let someone with actual transmission experience chime in on this. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/rolleyes.gif) First post by the Doc I've seen in a looooooonnnnngggg time. |
Lo-Fi Version | Time is now: 29th May 2024 - 12:07 AM |
