Idle speed question, Fast idle when cold.. |
oakdalecurtis |
Jan 30 2017, 01:32 PM
Oakdalecurtis Group: Members Posts: 1,328 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
May be a stupid question, but here goes. I have a stock 76 2.0. I had it up on blocks for a few months recently while I did a lot of fix ups. I installed the missing bellows thermostat (works great), new throttle position board, new trigger points, new plug wires, cleaned up throttle body, and reattached the broken wire lead to the ambient air temp sensor next to the throttle body. The engine runs flawlessly from the get go for the first time since I've owned it, as it used to intermittently miss under hard acceleration. I'm in California, so the coldest it gets outside is 35 degrees. When I first start the car, it idles fast at around 1500 rpm, then settles down after warm up to a nice 600 to 700 rpm. Is that normal, is it the temp sensor on top of the engine causing it, and should anything be checked or changed?
BeatNavy |
Jan 30 2017, 02:46 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
It sounds like it is working the way it's supposed to. D-Jet has an Auxiliary Air Regulator (AAR) to provide more air to the engine when cold. Kind of an artificial vacuum leak that results in a higher idle. As the element inside heats up (either from heater coil inside or from the engine itself) it closes and the idle settles down.
I think 600 RPM is little low when warm, and you may want to adjust the idle bypass to bring it up a bit. |
JeffBowlsby |
Jan 30 2017, 03:03 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Idle speed should be set to 900 +/-50 RPM
Lo-Fi Version | Time is now: 6th June 2024 - 11:45 AM |
