Front trunk seal, Adhesive or not? |
mtndawg |
Feb 3 2017, 12:23 PM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
Can I replace the front trunk seal without using adhesive? Did the stock install use it?
Tom_T |
Feb 3 2017, 12:38 PM
Stock used adhesive - both in the gutter to hold it in, & the corners were all glued together as well.
If you don't use adhesive in the gutter, then it will stick to the lid & pull out every time you open the front lid, eventually damaging the seal. I'd recco using it, but make sure to clean & rust proof the gutter first with good primer/paint, if it's not been painted already. (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
mepstein |
Feb 3 2017, 01:18 PM
914-6 GT in waiting Group: Members Posts: 19,305 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Buy 914rubber.com new one and don't use glue. After it takes a "set" it should stay in place. It's nice to be able to pull it out and clean and dry the under the seal when it gets wet. Otherwise that seal hold the water for a while.
914_teener |
Feb 3 2017, 01:26 PM
914 Guru Group: Members Posts: 5,201 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Buy 914rubber.com new one and don't use glue. After it takes a "set" it should stay in place. It's nice to be able to pull it out and clean and dry the under the seal when it gets wet. Otherwise that seal hold the water for a while. (IMG:style_emoticons/default/agree.gif) You can also tap the channel with a rubber mallet to tighten up the fit where it is loose, I didn't use or need any. While your there; Grind and sand and treat any areas where it is needed or rusted. Drive. |
mtndawg |
Feb 3 2017, 02:12 PM
Thanks, I have a 914 rubber seal on the way so I'll try without.
Mark Henry |
Feb 3 2017, 02:16 PM
Just lay it in, it's a water trap. If it did stick to the hood I'd wipe a tiny bit of veggie oil along the lip. Also installing it on a hot sunny day should make it lay down nice. |
Shredhead |
Feb 3 2017, 07:36 PM
Member Group: Members Posts: 110 Joined: 10-August 15 From: CT Member No.: 19,047 Region Association: North East States |
I'd wipe a tiny bit of veggie oil along the lip. Also installing it on a hot sunny day should make it lay down nice. Whoa. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 31st May 2024 - 08:11 PM |
