suspension suggestions |
Rotary'14 |
May 2 2005, 12:58 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
Hi all,
I have an interesting dilemma. I am changing my suspension over to 5 lug, and my front struts are '69-'71 pinch bolt type Boge struts. I've had the struts and M calipers for a long time, and I've accumulated all the rebuild parts for my caliper, and front brakes( new rotors, wheel bearings, etc), but I still need to buy some shock inserts and ball joints. To be honest I didn't know about the difference in strut attachment and balljoints until I read some related posts on this and the bird forums. What I learned has given me some concern about the different methods to attach the strut to the ball joint. As part of my 5 lug swap, I am going to replace the ball joints anyways, so should I buy some early style pinch type ball joints, and use all the stuff I've accumulated,, or should I go searching for some different struts to go along with the new latemodel wedge pin type ball joints (that would give me peace of mind)? How expensive can > '72 Boge 911 struts be used? Thanks for reading,, -Rob |
Eric_Shea |
May 2 2005, 01:13 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
You know Rob... I'm sure you may get some different "opinions" but I doubt if any of those forthcoming opinions have ever wallowed out the base of a strut.
You're probably guessing by now that I think you'll be fine with what you have. Just make sure it's torqued down properly and come back and check it after a week. You should be good to go. Get the old style ball joints for your struts and call it a day. If you're that into piece of mind you can probably find some struts for around $150 a pair. I think this problem was rare. The newer style is better and solves the problem but I doubt seriously you'll ever have the problem. All that being said... if you plan to race it "rigorously", look for the later model units and rest peacefully. Hope that helps... |
jgiroux67 |
May 2 2005, 04:16 PM
Guitar Shredder Group: Members Posts: 593 Joined: 4-June 04 From: Turlock, CA Member No.: 2,157 |
I have a 73 and just put on 911sc struts. The ball joints fit in fine, but is there a problem with this set up? Should I get different ball joints? If so which ones?
Mueller |
May 2 2005, 04:19 PM
yours are fine, it's the earlier style that some people have had problems with..........early ones used a bolt that "pinched" the ball joint, the later style uses a wedge to hold the ball joint in the strut housing |
Lo-Fi Version | Time is now: 1st June 2024 - 01:24 PM |
