Engine won't rotate |
ruddyboys |
Feb 18 2017, 01:02 PM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
Trying to start, the engine cranking fine" then it just stops. Try spinning by hand still no go. Figuring maybe a push rod, they are fine. With no rockers on, engine still will not budge. We also put the car in gear and tried to push it, still engine won't rotate.
Larmo63 |
Feb 18 2017, 01:22 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
It has deeper issues I suspect......
jsaum |
Feb 18 2017, 01:52 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
When was the last time the engine ran? Was it sitting for an extended time?
ruddyboys |
Feb 18 2017, 02:04 PM
Haven't had it started, but it cranked just fine, then while cranking it just stopped
falcor75 |
Feb 18 2017, 02:08 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Pull the gearbox off and try again, check that the flywheel isnt jammed against some foreign object in the bellhousing. Pull the flywheel and try cranking it. If not it probably needs to come apart.
Bob L. |
Feb 18 2017, 02:16 PM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Have you tried turning it backwards? Maybe something wedged in the impeller fan/housing.
ruddyboys |
Feb 18 2017, 02:21 PM
Doesn't rotate backward. Tried putting in reverse and pushing, doesn't roll.
Dave_Darling |
Feb 18 2017, 02:53 PM
Inspect the fan. If there's nothing obviously wrong, either pull the fan off or remove the trans. If the engine still won't rotate, try the other of those two. If no go, pull the motor.
--DD |
porschetub |
Feb 18 2017, 08:20 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Any sign of oil in the valve covers when you pulled them off ? put some WD 40 or similar down the plug holes ,leave to soak and then try again with the plugs out.
Has the motor been out in the weather in the car or uncovered on its own,when did it last run as already asked,no one can help on here if we don't have the facts. |
Bartlett 914 |
Feb 19 2017, 09:30 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I had a similar issue once. The engine was fine but had been sitting for a year. Problem was carbon in the heads had come loose and was hitting the piston.
ruddyboys |
Feb 19 2017, 12:20 PM
Pulled the spark plugs and engine totes freely? Why would this happen
Mark Henry |
Feb 19 2017, 01:53 PM
Did any water/oil/gas come out of the plughole? Hydrolocked.
ruddyboys |
Feb 19 2017, 01:55 PM
No water oil or gas?
injunmort |
Feb 19 2017, 05:49 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
i see your in monroe. i am in chester. pm me i would be happy to swing by and give it a look.
type2man |
Feb 19 2017, 07:59 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
Perhaps a leaking fuel injector or if its carbureted, the floats could be getting stuck
IronHillRestorations |
Feb 19 2017, 09:55 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Don't hammer on the thing by trying to bump start. Pull all 4 spark plugs and then see if it will turn over. Next step would be to find a inspection camera and look in the spark plug holes.
Mark Henry |
Feb 20 2017, 06:15 AM
Pulled the spark plugs and engine totes freely? Why would this happen Are you saying that it turns over freely without the plugs? Don't hammer on the thing by trying to bump start. Pull all 4 spark plugs and then see if it will turn over. Next step would be to find a inspection camera and look in the spark plug holes. (IMG:style_emoticons/default/agree.gif) good way to bend a rod. |
injunmort |
Feb 20 2017, 06:39 PM
check your pm inbox
zambezi |
Feb 20 2017, 08:23 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
I had a similar situation as well. Turned out to be the starter bendix was hanging up and jamming the flywheel. It happened to me twice and I thought the motor was locking up but when I started to pull the starter I heard a pop as the bendix pulled itself back free from the flywheel. I ended up replacing the starter with a gear reduction and have not had a problem since.
Lo-Fi Version | Time is now: 8th June 2024 - 11:17 PM |
