fuel pump recommendation, Ned a new one, where to buy and what brand? |
914 RZ-1 |
Feb 18 2017, 08:08 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
Where is a good place to buy and what brand of fuel pump should I get?
I have a 1.7L engine. I currently have a non-functional aftermarket one (the OEM ones are NLA). Thanks! |
boxsterfan |
Feb 18 2017, 08:40 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Local FLAPS will have one. Napa, O'Reilley's, Autozone, etc....
Dave_Darling |
Feb 19 2017, 12:16 AM
Carbureted? Injected?
--DD |
PlantMan |
Feb 19 2017, 01:02 AM
Member Group: Members Posts: 438 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California |
Airtex from Amazon for about $70.
Harpo |
Feb 19 2017, 06:18 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
If you have carbs then I recommend tangerine racing (Chris Foley)
David |
JoeD |
Feb 19 2017, 06:46 AM
Member Group: Members Posts: 156 Joined: 19-July 15 From: Atlanta, GA Member No.: 18,973 Region Association: South East States |
If you have carbs then I recommend tangerine racing (Chris Foley) David (IMG:style_emoticons/default/agree.gif) |
914 RZ-1 |
Feb 19 2017, 03:58 PM
I have fuel injection.
JawjaPorsche |
Feb 19 2017, 07:45 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
If you have a 1.7, you probably have a three prong pump. Impossible to find. Convert over to a two prong pump. Easy to do because I did it. Got pump from NAPA.
914 RZ-1 |
Feb 19 2017, 09:32 PM
If you have a 1.7, you probably have a three prong pump. Impossible to find. Convert over to a two prong pump. Easy to do because I did it. Got pump from NAPA. I did that. The aftermarket, 2 prong pump went out. I could buy the same one, but I thought I'd ask anyone if they had a better, more reliable brand. Maybe I got a bad one. What brand did you buy and about how much was it? |
914 RZ-1 |
Feb 19 2017, 09:37 PM
PlantMan |
Feb 20 2017, 01:27 AM
Airtex from Amazon for about $70. Is this for carbs or FI? Couldn't find it on Amazon among the 20 or so that showed up. Can't go by make and model since I'm looking for a non-OEM one. E8445 is the model number and is great for the FI cars. I found this pump from other members here. You can pick it up for under $70 on Amazon. |
JawjaPorsche |
Feb 20 2017, 04:27 AM
Bosch Fuel Pump
At NAPA Part Number: BSH 69133 $98 five years ago. Hope this helps. If you have a 1.7, you probably have a three prong pump. Impossible to find. Convert over to a two prong pump. Easy to do because I did it. Got pump from NAPA. I did that. The aftermarket, 2 prong pump went out. I could buy the same one, but I thought I'd ask anyone if they had a better, more reliable brand. Maybe I got a bad one. What brand did you buy and about how much was it? |
Tbrown4x4 |
Feb 20 2017, 04:55 AM
Senior Member Group: Members Posts: 704 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Mark Henry |
Feb 20 2017, 06:53 AM
Hands down the best pump is Walbro, I won't even piss around with any other pump now.
But beware, when you are the best there will be fakes. On ebay, etc., if the prices are cheaper then they are on the Walbro site it's 99.9% guaranteed to be a fake. Stock listing for 75-76 914 2.0, $105 http://walbrofuelpumps.com/porsche-914-197...4-cyl-2-0l.html These below are good for aftermarket EFI, but the small one also should work just fine on a stock 914. By the time you add the fittings about the same price as above. If you do want to change the inlet/outlet sizes this is the best pump choice. Good to 400hp, $95 http://walbrofuelpumps.com/walbro-gsl392-i...55lph-pump.html Up to 670hp, $95 http://walbrofuelpumps.com/walbro-gsl392-i...55lph-pump.html Never tried their carb pump, $108 http://walbrofuelpumps.com/walbro-gsl395-fuel-pump.html BTW Walbro is made in the USA (IMG:style_emoticons/default/flag.gif) |
cary |
Feb 20 2017, 09:17 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
This is what I'm running. Don't drive too many miles per year. But hasn't missed a beat.
http://www.rockauto.com/en/moreinfo.php?pk...358&jsn=358 Road trips I carry a spare in the spare tire. But my fuel pump is in the spare tire well. But if I was replacing mine now I'd go with Mark's suggestion. |
914 RZ-1 |
Feb 20 2017, 10:38 PM
Hands down the best pump is Walbro, I won't even piss around with any other pump now. But beware, when you are the best there will be fakes. On ebay, etc., if the prices are cheaper then they are on the Walbro site it's 99.9% guaranteed to be a fake. Stock listing for 75-76 914 2.0, $105 http://walbrofuelpumps.com/porsche-914-197...4-cyl-2-0l.html These below are good for aftermarket EFI, but the small one also should work just fine on a stock 914. By the time you add the fittings about the same price as above. If you do want to change the inlet/outlet sizes this is the best pump choice. Good to 400hp, $95 http://walbrofuelpumps.com/walbro-gsl392-i...55lph-pump.html Up to 670hp, $95 http://walbrofuelpumps.com/walbro-gsl392-i...55lph-pump.html Never tried their carb pump, $108 http://walbrofuelpumps.com/walbro-gsl395-fuel-pump.html BTW Walbro is made in the USA (IMG:style_emoticons/default/flag.gif) Thanks for the info! (IMG:style_emoticons/default/beerchug.gif) I have a 1972 1.7L. Search results turned up nothing. But, will any of these pumps work anyway? |
914 RZ-1 |
Feb 20 2017, 10:41 PM
[quote name='JawjaPorsche' date='Feb 20 2017, 02:27 AM' post='2456360']
Bosch Fuel Pump At NAPA Part Number: BSH 69133 $98 five years ago. Hope this helps. It does, thanks! (IMG:style_emoticons/default/beerchug.gif) It's currently $114 ($103 if ordered online and picked up). |
brownaar |
Feb 21 2017, 08:48 AM
Member Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None |
Bosch 69133 on Amazon is $83. No brainer if you have Prime. That's where I got mine. Best upgrade I've done.
Lo-Fi Version | Time is now: 1st June 2024 - 12:08 PM |
