close Shave, Taking the covers off for morning 6 |
forrestkhaag |
Feb 22 2017, 10:30 AM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
Does anyone out there know if I need to shave or mill my turbo value covers prior to insertion of my my six motor? Larmo63 indicted that it is necessary or could be needed to fit the engine in the bay... If so, how much and what fins or maybe all fins. But the valve cover studs are taller than the fins ..
Cheers |
mskala |
Feb 22 2017, 11:14 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Does anyone out there know if I need to shave or mill my turbo value covers prior to insertion of my my six motor? Larmo63 indicted that it is necessary or could be needed to fit the engine in the bay... If so, how much and what fins or maybe all fins. But the valve cover studs are taller than the fins .. Cheers It's sort of the opposite of what you said. Engine can be installed or removed with turbo covers in place. However, turbo covers cannot be installed or removed from engine once installed unless some milling is done. It's not really an area that can be easily described. A choice if you have them is to install old covers with only 1 nut, install engine, then see what needs to be milled a little at a time. Or, some people have just taken down the whole thing evenly (I don't know how much). |
Mark Henry |
Feb 22 2017, 11:35 AM
I just milled mine right down to the top of where the nuts mount, I think you are left with just over a 1/4" on the ribs.
Some just trim where it interferes with the suspension. If you do a search there was a thread on this only a few weeks ago. |
GeorgeRud |
Feb 22 2017, 11:39 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
gcrotvik |
Feb 22 2017, 12:15 PM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
Here are 2 Garage threads that discuss this also:
http://www.914world.com/bbs2/index.php?sho...=303683&hl= http://www.914world.com/bbs2/index.php?sho...=303517&hl= |
forrestkhaag |
Feb 22 2017, 03:47 PM
Thanks to all contributers / I am off to the milling machine.......... (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 7th June 2024 - 08:09 PM |
