GC or GA case? |
GC or GA case? |
mtndawg |
Feb 23 2017, 01:54 PM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
I have a '75 2.0L car and just took a GA engine out of it. I think GA was used for that year? Please correct me if I'm wrong. I also have a GC case. Is there a big difference between the cases?
Tom_T |
Feb 23 2017, 01:57 PM
Nope - it's a transplant, & your car could've originally been a 1.8 or 2.0, which you won't know without documentation or from a COA.
GA - 73-74 GC - 75-76 914 Info link at the top right of every page on here is your friend! (IMG:style_emoticons/default/smile.gif) http://www.914world.com/specs/engnumbs.php PS - the cases were basically the same, but there are some differences - as the GC was detuned & used a Crapalytic Converter for CA, so the 2.0 turned out less HP either way CA (least) or 49 state. The chart at the link above says 95 vs 88 HP, but IIRC from when I test drove a new 75 & 76 in 1975 before deciding on my 73 2L - the CA detuned 2L was only 86 HP due to the added CAT. PSS - If you can prove the car was a factory 2.0, then you may want to use the GC motor so that it's close to correct - especially if the case number/motor was originally in that 914 - making it a numbers matching car. If it's a converted 1.8, then you could use either - probably the one in best condition, & you may want to consider making it a 2056 (talk to McMark at Original Customs on that - see his banner ad). Stay dry up there! (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
mtndawg |
Feb 23 2017, 02:04 PM
Beautiful, thanks Tom.
gcrotvik |
Feb 23 2017, 03:08 PM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
Take a look at the engine number chart here: http://p914.com/p914_engine.htm
See if the GC case serial number is in the serial number range for a 75 motor, if so it may be the original motor. Only a COA will tell you that for sure. If not, it's a transplant. |
TheCabinetmaker |
Feb 23 2017, 04:27 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I've rebuilt many engines of the ga/gc variety. I don't think there is any difference in the cases. 75/76 heads were different as was the exhaust.
Dave_Darling |
Feb 23 2017, 06:21 PM
The heads were only different on some of the GC motors, the ones with air injection. Those have the extra holes into the exhaust ports. Other than that, they are the same as the GA heads. And there were GC motors without supplemental air injection; their heads were the same as the GA heads.
The only real difference between the two motors was the terrible horrible no-good exhaust on all of the 75-76 914s. There were different part numbers used in a lot of the FI components as well, but those differences appear to be relatively subtle. The exhaust is the big difference. --DD |
Mark Henry |
Feb 23 2017, 06:35 PM
Is it an early 75?
VW is famous for using up stock on hand, so I could easily believe a GA case is OE in an early build '75. |
cgnj |
Feb 23 2017, 07:54 PM
Senior Member Group: Members Posts: 624 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
I believe the oil pressure relief circuit is slightly different on GC cases. That's why the casting number is different.
Lo-Fi Version | Time is now: 1st June 2024 - 10:58 AM |
