Shift Rod Screw Question |
Ansbacher |
Feb 25 2017, 11:14 AM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Are both tapered screws that retain the shift rod (one near the firewall and one near the transmission) supposed to be the same screw? When I did my shift rod bushing job yesterday, I noticed the screw near the firewall looks like what is pictured below, but the one near the transmission has a hex head that takes a socket. I want to buy new screws but I only see ones like below, so am assuming they are supposed to match? Input appreciated. - Ansbacher in Tampa Bay
TheCabinetmaker |
Feb 25 2017, 11:21 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
That is the correct screw. They are said to be a one time use screw. I just use blue locktite. I've never had one come loose..
Ansbacher |
Feb 25 2017, 11:25 AM
Krieger |
Feb 25 2017, 11:41 AM
Advanced Member Group: Members Posts: 4,723 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
They should be the same. Sounds like somebody might have stripped the threads and came up with a home brewed fix. They drilled and tapped a bigger hole and fit a bolt they tapered. Take a picture. The rear piece is easy and inexpensive to swap out.
rhodyguy |
Feb 25 2017, 12:09 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Just replace the rear coupler if the threads have been oversized. JWest, member vendor, sells a tapered screw that incorporates a jam nut. No Loctite needed for reuse. Unless you've changed it out recently plan on a new ball cup bushing for the coupler.
IronHillRestorations |
Feb 25 2017, 12:50 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I've got one of those square head taper screws, but I only use it for my shift rod jig.
The one in the pic is the right one, and it should have a little dowel of nylon inserted in the threads to hold it in place. Alternately you can do as Curt said and a small dab of blue locktite is just as good. |
MartyYeoman |
Feb 25 2017, 03:46 PM
Senior Member Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
(IMG:style_emoticons/default/agree.gif) Use these with safety wires. No worries.
Attached image(s) |
Ansbacher |
Feb 25 2017, 04:28 PM
Thanx all for the goldmine of information. I know what to do and need now.
Ansbacher |
Lo-Fi Version | Time is now: 1st June 2024 - 10:07 AM |
