Harnessing my inner self, main bulkhead harness question |
ahycaramba |
Mar 9 2017, 09:58 PM
“I live my life a quarter mile at a time.” Group: Members Posts: 161 Joined: 17-March 15 From: Murrieta, California Member No.: 18,534 Region Association: Southern California |
Hello Fellow teeners,
I am in the process of doing a resto mod using the Subaru ej20 motor and trans. I have the harness to run the engine management. I just need the main bulkhead harness to run all the lights and interior electronics (gauges, radio, etc.) I was wondering what others are doing? I see Kroon has 914-6 harness available. Has anybody used the bulkhead harness alone minus EFI portion of the harness from kroon. Can it be done? Can anybody recommend me where to buy main bulkhead harness? (IMG:style_emoticons/default/confused24.gif) much appreciated. (IMG:style_emoticons/default/beerchug.gif) Al |
mepstein |
Mar 10 2017, 06:59 AM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Just place a - want to buy - in the classifieds. The kroon harness is $2K. You should be able to pick up a 914-4 harness for around $100 +\-
JeffBowlsby |
Mar 10 2017, 08:41 AM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
There is no "bulkhead harness" on a 914. It serves the entire chassis from the headlights to the taillights. The engine bay harnesses simply plug into it at the relay board.
76-914 |
Mar 10 2017, 10:11 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
All you need to do is remove the relay board and the 14 pin connector. You'll need the yellow starter wire, the 12v switched hot wire, fuel pump wire and a few others I can't remember at the moment. Just look at the schematic for the relay, delete those not needed. IIRC, it's in my build thread. (IMG:style_emoticons/default/beerchug.gif)
ahycaramba |
Mar 10 2017, 05:48 PM
thanks for your wealth of information guys.
very much appreciated. (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/beerchug.gif) cheers, Al |
Lo-Fi Version | Time is now: 1st June 2024 - 03:52 PM |
