Getting a '91 964, pitfalls |
IronHillRestorations |
Mar 14 2017, 06:33 AM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I've made a deal on a '91 964. I would've preferred a coupe but I found a good deal on a 98k mile targa.
I know about the flywheel/clutch problem (it has a new clutch), and the cylinder head sealing problem (this one is clean and dry). I am getting a PPI by a very reputable independent Porsche shop. What do those among us say to avoid on these? I've had a 964 before, and aside from a 71 S, it's my favorite incarnation of the 911. |
EdwardBlume |
Mar 14 2017, 07:01 AM
I had a 993, and the belt drive on the dual distributors was a key item on the 3.6. The wiring harness was recalled as well.
Mark Henry |
Mar 14 2017, 08:07 AM
Can't remember if it's the 964 or 993 has ceramic valve guides that are prone to cracking. Hard to check without removing the exhaust.
Best place to ask this is over on the bird or rennlist 964 forums. |
JFJ914 |
Mar 14 2017, 08:46 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
I've made a deal on a '91 964. I would've preferred a coupe but I found a good deal on a 98k mile targa. I know about the flywheel/clutch problem (it has a new clutch), and the cylinder head sealing problem (this one is clean and dry). I am getting a PPI by a very reputable independent Porsche shop. What do those among us say to avoid on these? I've had a 964 before, and aside from a 71 S, it's my favorite incarnation of the 911. I had a '90 Coupe, leaked like a sieve, case through bolts, valve cover gaskets ect. Distributor belt broke, not a big deal to fix your self. (x$20 for the belt) If it's hard to start, probably the fuel pressure regulator leaking internally, floods the engine. Got it and a lot of parts really cheap on Amazon using the Bosch part numbers. |
mb911 |
Mar 14 2017, 09:47 AM
914 Guru Group: Members Posts: 6,882 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Mine was pretty reliable. It made more valve train noise then I liked, Had one coil go bad on it, it was a resealed engine with 80k (total on the car and engine) on it and it still leaked and all the paperwork for the reseal and new pistons and cylinders was from a reputable shop in CA, Shifted great. I made an outstanding muffler for it because at the time I owned M&K exhaust and sold the designs and they were never used by the new owner. Overall a nice car but for 80k on it allot had been done to it already engine wise so that surprised me.
RickS |
Mar 14 2017, 10:06 AM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
If you want info, go to the board devoted to your model. http://forums.pelicanparts.com/porsche-964...echnical-forum/
Steve |
Mar 14 2017, 11:44 AM
914 Guru Group: Members Posts: 5,613 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
The issues I heard of compared to 993
-old school barn door air flow meter -no hydraulic lifters (have to adjust valves) -need to modify distributor with a breather -leaky heads, due to no head gasket. Specific year? |
Lo-Fi Version | Time is now: 9th June 2024 - 01:49 AM |
