Brando |
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California ![]() |
Can't seem to find anyone who makes one. I plan to change over to different calipers and I'd like to replace the stock proportioning valve with a T fitting. Tried all the usual suspects and no luck. Not even the local 914/VW stores have anything. Where should I look?
Thanks (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
914GT |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region ![]() |
I bought a Tee from Chirco, a local VW supply store.
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
got mine from the local bug/vw shop in novato ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Ray Warren |
Member ![]() ![]() Group: Benefactors Posts: 415 Joined: 1-October 03 From: Canada Member No.: 1,214 Region Association: None ![]() ![]() |
This is the one I used. Worked well. "T" FITTING |
gklinger |
doh! ![]() ![]() Group: Members Posts: 316 Joined: 14-January 03 From: Tempe, AZ Member No.: 146 Region Association: Southwest Region ![]() |
CB Peformance:
Metric Brake Line "T" Factory replacement Brake Line 'T'. Fits rear brake line on VW Sedans, Squarebacks, and Buses. The Metric 'T' is tapped to accept 9.3mm threaded fittings and 4.7mm OD steel brake line with bubble flared ends. Part# Description Price 3985 Metric Brake Line T $9.95 |
smg914 |
Sahara Beige Steve ![]() ![]() ![]() Group: Members Posts: 1,962 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None ![]() ![]() |
The last one I bought was from a VW Speed/Dune Buggie Shop. Paid $7.00 for it. As a last resort, you can order one from your local Porsche dealer. I believe early 911's used the "T".
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
any VW shop should have it... I don't believe the bugs or bus' have a prop valve... just the "T"
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
buy 2 buddy - one fo meee
http://www2.cip1.com/ProductDetails.asp?Pr...803%2D611%2D755 |
Leo Imperial |
Do you have to use so many cuss words? ![]() ![]() ![]() Group: Members Posts: 906 Joined: 29-November 04 From: 914 Roadshow - Glen Cove NY Member No.: 3,192 Region Association: None ![]() |
I was there yestarday. I think it's the same place. Viking Autoparts in Novato. The guy who runs the place is Bryan. The number is 415-892-6992. I will be going there some time next week to pick up a few things and could pick it up and send it to you. Leo |
mattillac |
robots! ![]() ![]() ![]() Group: Members Posts: 536 Joined: 27-October 04 From: vallejo,ca Member No.: 3,020 ![]() |
what do you need the T for. adjustable prop. valve?
JWest |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None ![]() ![]() |
How about supporting a 914 club vendor? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
JWest Brake Products You'll have it in 3 days after ordering. |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
one our own club members sells them:
J West Engineering
when upgrading the brakes to new/larger calipers, sometimes the brake bias works fine without a prop. valve leave yours in............. |
Brando |
Aaron & Jwest... Done and done (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Rather support a club member than some other VW shop... |
JWest |
Thanks! They go out today - look in your mailbox on Monday or Tuesday. |
CptTripps |
:: Punch and Pie :: ![]() ![]() ![]() ![]() Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest ![]() |
This is the wrong one... I called and ordered that part number, and he said that that one has the wrong flare. I'll get the part number, but the one with the bubble-flare is $16.50. I'll have one tomorrow... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
RON S. |
9140430841, FINALLY RUNNING ![]() ![]() ![]() Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States ![]() |
I found out that all the 60-70's Beetles have that same fitting in the rear,up behind the driver's side wheel well.
Carry your wrenches,and go junkyarding.With a little luck,a salvage yard owner will laugh and just let you have it for the effort you spent to take it off. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Ron |
JWest |
You could have had one from me for $9.95 and only $3.85 shipping. |
914GT |
I thought that price seemed a little low. But it's been two years ago and the memory is failing. |
CptTripps |
I bought it after the first post. You hadn't chimed in yet! Next time. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Lo-Fi Version | Time is now: 17th June 2024 - 10:01 AM |
