tbone1819 |
Newbie ![]() Group: Members Posts: 26 Joined: 1-February 17 From: Lynbrook NY Member No.: 20,800 Region Association: North East States ![]() |
If i have a transmission,linkage and shifter from a 1971, could i put it into my 73?
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,843 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Why would you go from a side-shifter transaxle to a tail-shifter? But yes, assuming you swap over all of the various parts unique to a tail-shifter to go into your side-shifter it should work. I say that based upon the fact we upgraded my tail-shifter Six transaxle to a side-shifter because it is a better shift mechanism. So I see no reason it could not go the other way too.
tbone1819 |
Why would you go from a side-shifter transaxle to a tail-shifter? But yes, assuming you swap over all of the various parts unique to a tail-shifter to go into your side-shifter it should work. I say that based upon the fact we upgraded my tail-shifter Six transaxle to a side-shifter because it is a better shift mechanism. So I see no reason it could not go the other way too. Do you have a photo of both examples of these transmissions? I am so new to these cars. I needed synchros in my trans and found a guy who was selling his recently rebuilt one for $300, so I jumped on it. He gave me everything too. |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Ah, you responded while I was typing.
As Cairo said, you can swap the shifting bits from the later transmission to the earlier one and have the correct (and better!) shift linkage setup with the gearing and synchros and such from the earlier trans. --DD |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
To convert between a tail and side shifter requires changing the motor bar. Motor mounts. All 3 parts of the shifter itself and shift linkage
Your Tail shifter can internally be converted to a side shifter using your bad tranny as a core to take the rear cover and internal shifting forks out of |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Why? (IMG:style_emoticons/default/confused24.gif)
A 911-901 core is going for a good buck these days, sell it and you can likely buy a good 914 sideshifter core and all the new bits to do a full rebuild. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
The linkage on the firewall is different. It would be a lot of work to convert to the early linkage.
malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
Why would you go from a side-shifter transaxle to a tail-shifter? But yes, assuming you swap over all of the various parts unique to a tail-shifter to go into your side-shifter it should work. I say that based upon the fact we upgraded my tail-shifter Six transaxle to a side-shifter because it is a better shift mechanism. So I see no reason it could not go the other way too. Do you have a photo of both examples of these transmissions? I am so new to these cars. I needed synchros in my trans and found a guy who was selling his recently rebuilt one for $300, so I jumped on it. He gave me everything too. Google "914 transmission tail shift" or this link then open another browser and do: "914 transmission side shift" Under the input bar will be a way to look at IMAGES. Click the word "IMAGES". It won't take you long to see the difference. |
tbone1819 |
Why would you go from a side-shifter transaxle to a tail-shifter? But yes, assuming you swap over all of the various parts unique to a tail-shifter to go into your side-shifter it should work. I say that based upon the fact we upgraded my tail-shifter Six transaxle to a side-shifter because it is a better shift mechanism. So I see no reason it could not go the other way too. Do you have a photo of both examples of these transmissions? I am so new to these cars. I needed synchros in my trans and found a guy who was selling his recently rebuilt one for $300, so I jumped on it. He gave me everything too. Google "914 transmission tail shift" or this link then open another browser and do: "914 transmission side shift" Under the input bar will be a way to look at IMAGES. Click the word "IMAGES". It won't take you long to see the difference. Thanks guys! |
tbone1819 |
Why would you go from a side-shifter transaxle to a tail-shifter? But yes, assuming you swap over all of the various parts unique to a tail-shifter to go into your side-shifter it should work. I say that based upon the fact we upgraded my tail-shifter Six transaxle to a side-shifter because it is a better shift mechanism. So I see no reason it could not go the other way too. Thank you so much! |
mlindner |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,534 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest ![]() ![]() |
Like MarkHenry said, sell the 71...Then send your 73 to Doctor Evil for a tune up, he has all the parts needed. Best, Mark
Lo-Fi Version | Time is now: 17th June 2024 - 06:08 PM |
