kaiserms |
MSKaiser ![]() Group: Members Posts: 26 Joined: 8-September 16 From: waterford, michigan Member No.: 20,378 Region Association: Upper MidWest ![]() |
WTB: Looking for an 8 to 12 gal oil sump pump setup to fit a 914 2.2 motor. Please indicate the price and shipping cost. Thank you Kaiser |
kaiserms |
Sorry, meant qts not gallons.
Hold off on the size. Might be too large. Adding oil cooler to motor cover. Probably only need 3 qt sump.. Kaiser |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
do you mean that you want a high volume oil pump (mounted on the motor)
or are you looking for an accusump? which is not an oil pump really... although it is able to relieve its oil pressure back into the system sorry it just wasn't clear to me |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,542 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
kaiserms |
do you mean that you want a high volume oil pump (mounted on the motor) or are you looking for an accusump? which is not an oil pump really... although it is able to relieve its oil pressure back into the system sorry it just wasn't clear to me Sorry about confusion. The question is whether to go with just the basic 11/2 qt oil pan that is attached to the existing oil pan, or go to a dry sump oil tank that holds 8-12 gallons. I'm having a hard time finding a dry sump tank or prices. |
deemsriddle |
Newbie ![]() Group: Members Posts: 15 Joined: 1-January 17 From: Ringgold GA Member No.: 20,717 Region Association: South East States ![]() |
do you mean that you want a high volume oil pump (mounted on the motor) or are you looking for an accusump? which is not an oil pump really... although it is able to relieve its oil pressure back into the system sorry it just wasn't clear to me Sorry about confusion. The question is whether to go with just the basic 11/2 qt oil pan that is attached to the existing oil pan, or go to a dry sump oil tank that holds 8-12 gallons. I'm having a hard time finding a dry sump tank or prices. If you are looking for a high capacity 2 to 4 gallon oil tank for a race car, then I may have your answer. Let me know. |
bdstone914 |
do you mean that you want a high volume oil pump (mounted on the motor) or are you looking for an accusump? which is not an oil pump really... although it is able to relieve its oil pressure back into the system sorry it just wasn't clear to me Sorry about confusion. The question is whether to go with just the basic 11/2 qt oil pan that is attached to the existing oil pan, or go to a dry sump oil tank that holds 8-12 gallons. I'm having a hard time finding a dry sump tank or prices. Why do you need to add oil capacity? Street car? |
brant |
if this is a race car I can understand a dry sump system
expensive and complicated but can be beneficial if this is a street car.... you only need a tuna can these have traditionally been much preferred over a larger sump which bolts onto the motor. The deep sump is vulnerable to damage in road use, and also the case is not strong where these mount... so generally the tuna can accomplishes the same thing with less risk I actually run a 5 gallon (20quart) oil system on my race car but again, the application is very different than street use |
kaiserms |
do you mean that you want a high volume oil pump (mounted on the motor) or are you looking for an accusump? which is not an oil pump really... although it is able to relieve its oil pressure back into the system sorry it just wasn't clear to me Sorry about confusion. The question is whether to go with just the basic 11/2 qt oil pan that is attached to the existing oil pan, or go to a dry sump oil tank that holds 8-12 gallons. I'm having a hard time finding a dry sump tank or prices. Why do you need to add oil capacity? Street car? Race car, only. |
Lo-Fi Version | Time is now: 16th June 2024 - 11:37 AM |
