> Cabin heat coming in even with console handle down, Checked the heat valves
oakdalecurtis
post Mar 29 2017, 04:53 PM
Oakdalecurtis
I kept feeling a small amount of heat coming in on my feet even with the heat control down. I checked the cables and the heater valves underneath the car, it felt like they were closing when I manipulated them. I finally pulled the valves out, and one of them had a nut stuck in the valve gap so it wouldn't close all the way. No idea how the nut could have gotten there, but it's nice to drive now without the heater leaking into the cabin! Btw, I had no use for the disconnected CAT and EGR lights on the dash, so I black plugged one light and connected the other to the cabin heat switch. Now when I pull the console lever to get heat, a red light goes on in the dash to remind me that heat is on.
Replies(1 - 9)
mgphoto
post Mar 29 2017, 05:39 PM
"If there is a mistake it will find me"
Photo???
oakdalecurtis
post Mar 29 2017, 10:18 PM
Oakdalecurtis
Off, then On pic:
r_towle
post Mar 30 2017, 08:51 AM
Custom Member
There is a rubber seal in the flapper box, on the round flapper, that degrades over 40 years and allows leaks to happen. If it's still hot, change the mixture to include fresh air
barefoot
post Mar 31 2017, 08:43 AM
QUOTE(r_towle @ Mar 30 2017, 10:51 AM) *
Huh??? how do you do that? the flapper is either closed to the cabin or the atmosphere discharge or somewhere in between.
I expect you can get in there and use some hi temp RTV to re-nue the flapper seal.
rhodyguy
post Mar 31 2017, 08:52 AM
The heated air and cooler outside air can be mixed/blended with the dash controls but that won't be of much help on hot days. Is one dash outlet warmer than the other side when the center tunnel lever is pushed down (valves closed)?
Dave_Darling
post Mar 31 2017, 04:46 PM
914 Idiot
I remember that the flap inside the flapper valve is actually two pieces, riveted together. If the rivet fails the two pieces can separate, and that can send (at least some!) warm air into the interior at all times.
Alan Caldwell recommended using a nut and bolt to replace the rivet if the latter fails.
(Unless I'm thinking of some other valve that fails in this way....)
--DD
IronHillRestorations
post Apr 1 2017, 06:42 AM
I. I. R. C.
I had a car in that had the same problem. It was a broken impeller vane that got lodged in the flapper box and kept it open a little
post Apr 1 2017, 07:01 AM
914-6 GT in waiting
QUOTE(Dave_Darling @ Mar 31 2017, 06:46 PM) *
--DD
I fixed mine that way. Just a little heat on a hot summer day is too much!
r_towle
post Apr 1 2017, 08:50 AM
Custom Member
I removed the flexible hoses in the summer....that also worked
- Lo-Fi Version Time is now: 29th April 2026 - 07:00 PM
