OK! now im lost...., help...help.......help |
xsboost90 |
May 6 2005, 07:44 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
get the gas tank all mounted in and nice, then notice i forgot to switch out the old rubber fuel lines, so out w/ the tank and put the new lines on. Get the tank back in, rerun some botched PO wiring under the hood, put on some wire loom covering, now its time to pull the old motor out and have a look see......now im lost.
see, im a 944 guy, could build one in my sleep, this thing is all flattend out and squished!! Problem is my haynes manual sucks. The guy who built the motor i think mistakenly ran some pvc line instead of fuel line and its all hard, so i know ill be putting in some real fuel line. I have a bunch of little holes and plugs and such that i have no idea where things go, and the instructions for my crane cam optic ignition is so vague, im not even sure it has instructions for my distributor. Here is every pic i can think of...I need some advice. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) heres my distributor. So i take the points and condensor off....how do i find tdc w/ the engine on the stand w/ no flywheel?? Any pics of how to mount the optics, i have an idea but not which direction. Attached image(s) |
xsboost90 |
May 6 2005, 07:45 PM
here is the parts i have for it..
Attached image(s) |
xsboost90 |
what does this do? do i need to plug it?
Attached image(s) |
xsboost90 |
May 6 2005, 07:46 PM
and these??? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Attached image(s) |
xsboost90 |
May 6 2005, 07:47 PM
a plug that obviously isnt used?
Attached image(s) |
xsboost90 |
May 6 2005, 07:48 PM
how exactly does my fuel lines hook up, i have two fuel lines to hook up...where?
Attached image(s) |
grasshopper |
May 6 2005, 07:53 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
is that next to the manifolds? if so, there should be a bolt that goes in there. I think it have a spare. and the plug, do you mean the sensor down in there? umm...i dunno thats about all i know. still learning! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
mihai914 |
May 6 2005, 07:56 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
Go to the bird board and look up in the 914 tech section for Dave Darling's Vacuum Diagram and Fuel Diagram, many things should come back into place, that unused plug is the oil pressure sensor if that is what you are referring to. Here:
Damp Dave's Diagrams. Mihai |
markb |
May 6 2005, 08:00 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
One tip, DON'T use chopsticks to find TDC. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
nebreitling |
May 6 2005, 08:08 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
third pic is the vent to the head. you should plug it for now just so as crap doesn't get into it, but eventually you'll want to set a barb down in there in order breathe them (w/ hose, into a breather box or something).
the 'plug that obviously isn't used' is your oil pressure sender. re. the crane, everything you need is there, it's just a bit of a pain to set up. re. fuel lines, you'll have a send and a return from the tank into the engine bay, look at the pelican article (above) for orientation of them. good luck. use the search function and you'll figure things out! |
TravisNeff |
To find TDC on number 1, rotate the engine and look for the timing marks on the fan, or there is a line cut out in the flyhweel, which will be at the bottom. Once you get there, pop off the valve cover for number 1 cyl, check to see if both valves are slack. If not you are not on your firing stroke, rotate again until you get to the same marks - valves should be slack. If so, you found TDC Number on No 1. compliments of cap'n crusty from a loong time ago.
SGB |
May 6 2005, 08:29 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
thats right, the cooling fan has a mark that is viewed through the little hole in the cooling fan housing. There is an article on the "tech articles"
914 timing with carbs on pp Remove the round black plastic cap and look ind It has this picture- Attached image(s) |
TravisNeff |
May 6 2005, 08:34 PM
Picture is worth a thousand words - just remember - that just because the timing mark shows TDC doens't mean it is, the engine rotates 2 times per firing cycle, that is why I stated check your valves on No 1 to be slack - make sense?
xsboost90 |
May 6 2005, 08:38 PM
nice! thanks for the info, im feeling alittle better! The optic ignition, does this have to be put in a certain spot, like exactly on number one?
oh yeah i get the whole valve thing, been there before. |
brp914 |
May 6 2005, 08:40 PM
Unregistered |
If you really insist on putting that optical thingy on, carry a set points and tools for when it craps. Mine lasted about a year when the module died. They replaced the module. It or something else went a year or so after that. Ditched it. 2+ years on a pertronix now and no prob's. Easier install to boot.
wilchek |
May 7 2005, 01:44 PM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
maybe this will help with lines
Attached image(s) |
wilchek |
May 7 2005, 01:46 PM
and closer
Attached image(s) |
wilchek |
May 7 2005, 01:55 PM
and sensor looks like green/red wire goes to it.
Attached image(s) |
wilchek |
May 7 2005, 01:58 PM
it looks like it comes out of wiring harness here
Attached image(s) |
xsboost90 |
May 7 2005, 03:10 PM
ok, figured out the fuel lines, i think the guy had some vac line run instead of fuel line, a year old and they are hard as a rock? I think i figured out the distributor, got the engine off the stand and set to tdc, then set distributor in and figured out where to mount the sensor for the crane cam unit. FINALLY got it all to clear each other w/o interfering w/ the vac advance and itself. Now i have a question..or two.
Does anyone have a dist hold down bracket they can get rid of???? Attached image(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 01:21 AM |
