NJTom |
Member ![]() ![]() Group: Members Posts: 96 Joined: 16-July 14 From: NJ Member No.: 17,643 Region Association: None ![]() |
One step forward two steps back. We started and drove our 1972 project 914. In my book that's a miracle! We put in a rebuilt 1974 2.0, here's the question today. When the starter engages we get sir a split second a loud almost grinding sound. Like I said less than a second. Everything seems fine, my car guy thinks maybe we are missing a plate or spacer that would move the starter off the engine a tiny bit. My other car guy says it will go away as the gears mesh over time. Any thouhsz? This forum has been a God sent! I cannot thank everyone enough!
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
One step forward two steps back. We started and drove our 1972 project 914. In my book that's a miracle! We put in a rebuilt 1974 2.0, here's the question today. When the starter engages we get sir a split second a loud almost grinding sound. Like I said less than a second. Everything seems fine, my car guy thinks maybe we are missing a plate or spacer that would move the starter off the engine a tiny bit. My other car guy says it will go away as the gears mesh over time. Any thouhsz? This forum has been a God sent! I cannot thank everyone enough! Sounds like it may need some shims. This happened with some of the "high torque" starter replacements... the plunger went too deep. Spacing it back was a fix. It's good that you are questioning it soon, so you can fix it before more damage is done. |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,739 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
To begin with; stock starter or some FLAPS starter?
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,566 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
I put in a high torque starter that did the same thing. One washer shim between the starter and case offset it enough to clear the flywheel. And congrats on the first start! |
NJTom |
One step forward two steps back. We started and drove our 1972 project 914. In my book that's a miracle! We put in a rebuilt 1974 2.0, here's the question today. When the starter engages we get sir a split second a loud almost grinding sound. Like I said less than a second. Everything seems fine, my car guy thinks maybe we are missing a plate or spacer that would move the starter off the engine a tiny bit. My other car guy says it will go away as the gears mesh over time. Any thouhsz? This forum has been a God sent! I cannot thank everyone enough! Sounds like it may need some shims. This happened with some of the "high torque" starter replacements... the plunger went too deep. Spacing it back was a fix. It's good that you are questioning it soon, so you can fix it before more damage is done. Thanks! |
Lo-Fi Version | Time is now: 15th July 2025 - 03:32 AM |
